Old 08-13-2007, 02:36 PM   #1
I love Airstreams...
leefields's Avatar
1989 29' Land Yacht
Haines City , Florida
Talking It's Soooooo Hooooot outside.....
that i actually started calling around orlando looking for an air conditioned storage place big enough to put my squarestream in so i could do work on it...
i have spent a couple of hours the past few days working inside with no electric for the AC....which i need to replace.....i was drenched yesterday afternoon after just a few minutes....97 degrees outside...must have been 2000 degrees inside...windows open...
how hot is it where your at.....???????
1953 Spartan Mansion
Ram 3500 DRW LB SuperCrew
PCS Professional Coach
AIR# 6366
leefields is offline   Reply With Quote
Old 08-13-2007, 02:50 PM   #2
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
105 in the valley today
Los Angeles-----but its a DRY heat!!
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 08-13-2007, 02:51 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
21% Humidity is a little high for us this time of year!
Not too bad here today:
Partly Cloudy
89°F
Feels Like 86°F
Updated Aug 13 02:25 p.m. MT
UV Index: 5 Moderate
Wind: From SW at 1 mph
Humidity: 21%
Pressure: 29.91 in.
Dew Point: 45°F
Visibility: 10.0 miles
Supposed to hit upper 90's though by the heat of the day ~
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 08-13-2007, 02:54 PM   #4
leefields's Avatar
1989 29' Land Yacht
let me try this again.....it is sooo hot that....
i sweated of 10 lbs just getting out of my truck.......i sprayed cold water on my airstream because i was afraid it would melt....now ....your turn....
AIR# 6366
Old 08-13-2007, 03:32 PM   #5
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
It was sooo hot over the weekend that the new Vulkem I was trying to seal with was running down the aluminum like a trickle of water......
www.nesa.org
Air No. 6427
Old 08-13-2007, 03:39 PM   #6
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
It is sooooo hot in Arkansas that all vegetation surrounding our reflective aluminum motorhome and trailer have burst into flames!
(You can also see the shiny reflective Airstreams from orbit!)
Sigh.
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 08-13-2007, 03:39 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Hot, Hot, Hot!!!
106 in my yard in Little Rock yesterday afternoon, but at least it was miserably humid! It also helps that there is not a single tree in my yard.
The AC on my Excella has been short cycling in the heat (another thread). Out of desperation, I installed (laid on the top of the AS) some of those fogger heads from a drip irrigation system. One cooling the AC condenser. Stopped it from short cycling and made 12 degrees difference.
Gotta get the $$$ saved up for a new AC.
Vaughan
Old 08-13-2007, 03:42 PM   #8
leefields's Avatar
1989 29' Land Yacht
nice.....
that was good...
AIR# 6366
Old 08-13-2007, 03:42 PM   #9
richinny's Avatar
2011 34' Classic
........... the potatoes i left inside, turned to French fries!
i can't say i remember a summer that stayed this hot for so long. i'd try working at night if you can.
Old 08-13-2007, 03:46 PM   #10
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
It's so-o-o hot here in midMO and especially inside our unairconditioned Gypsy that I set out two dozen canning jars inside on the dinette, capped them, tested for good seals, and now we have canned heat at a toasty 102 degrees to open up on our fall/winter trips. Putting this misery to good use ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 08-13-2007, 03:46 PM   #11
Got gandkids?
Hey Vaughn, do you suppose one of those Fogger what-cha-ma-call-its would cool the skin of my Airstream enough to let the Vulkem set up?
BTW, I wish you would start a thread on that, I'd like to hear more about it.
www.nesa.org
Air No. 6427
Old 08-13-2007, 03:55 PM   #12
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
106 today with the humidity at 50% just gotta love Mississippi in the summer time. Every time I pull in the driveway the Airstream tells me it's time to camp, but it's just to blame hot.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 08-13-2007, 03:56 PM   #13
1983 34' Excella
1967 24' Tradewind
Images: 32
Rivet Onward Through The Fog
Hi Jim,
I will do that. I just borrowed a digital camera and will put up some shots later when I get home.
Keep in mind, It is a temporary thing. I don't want water on the roof all the time, but it kept the inside 91 while it was 105 and 106 for hours. Without it, the compressor would short cycle and allow the interior temp to exceed the outside temp.
Vaughan
Old 08-13-2007, 04:35 PM   #14
BDandTTs's Avatar
2005 22' International CCD
Phoenix , Arizona
Images: 49
It's soooo hot today ...
in the rest of the nation, and I hope you can keep a secret.
High today at our house in Vermont was comfortably below 80, currently it is 72 and we might have to use an extra light blanket tonight when the temperature drops to the low 50's.
Wish we store some up perfect temperatures to enjoy in February!
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
http://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
1968 17' AS--- Caravel? Value? Ultradog 1966-68 Caravel 6 09-17-2006 08:40 PM
This is soooooo!! Cool!! Hi everybody!! martooon Member Introductions 23 06-09-2006 08:08 PM
