Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 01-26-2007, 12:20 AM   #29
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
a dangerous issue whenever ice storms happen...
is powerlines, downed power lines, LIVE down power lines...
NEVER EVER go near a line, touch a branch or even duck under a line...
very bad things will happen...
This is so important. A firefighter was killed about a year ago, when he contacted a power line that was hidden in a down tree. A line may look dead but may be live, or the power equipment may recycle the relay in an effort to restore power. When this happens, lines can jump - stay well clear, don't step over them, etc.
Another key point is to stay away from metal fences such as Cyclone or barbed wire if you suspect wires may be down in the area. They may carry the power to you from the downed wires a great distance away.
Good safety post with some great things to think about. Karma.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-26-2007, 01:26 AM   #30
SilverToy
Profile:  1992 34' Limited
Falls Church , Virginia
Escape handles are....
Pamelake -
As far as my limited AS experience goes, there are RED handles on the designated "escape windows". Those are ones that will fold completely away and allow total egress. Perhaps not gracefull but then gracefull isn't what one thinks of in that situation.... It's later that we laugh.
Check to see that you know all the locations in your unit (ALA the Escape routes that are forever talking about on planes these day!?!!!) and also know where everyone will likely be sleeping (overnight scenario) so that no one get forgotten!!!! A nearby meeting place ensures that everyone is accounted for - a not to be over looked ( but OFTEN IS!!!!!) portion of of all this.
Be sure that everyone is aware - should the situation get SERIOUS - break a window (front or rear, either by agreement or by situation (Fire) with the heaviest thing in the trailer. Break it - then dive out of it. It may not be pretty or glamourous, but then you're Getting air, your out and the air is critical, CRITICAL!!!!!!!! AirStream be damded, they make more.
Fixing, or not damageing the trailer further, is at least tertiary on the critical items list for a INS. CO.! Prioritized to manage the unfortuate situation and get people back into the life they are loving, and hate to leave, we need to make this whole again, ASAP!!!
WE campers can be EXTREMELY CLEAR in what our EXACT NEEDS are and WHEN WE EXPECT TO GET THEM. They are after all dealing with a LOT of people that want resolution that second.... Pressure baby!!!!
A reasonable listening/info gathering attitude, coupled with a very resonable counter offer ( with solid documentation! x3 or 4) and then a serious dialog explaning both sides, then hashing it all out (IN YOUR FAVOR!!!) and then getting the check(s) post haste..... all make for a resonable insurance Co. interaction.... Likely the best one can hope for these days. Sigh.
SilverToy is offline   Reply With Quote
Old 01-26-2007, 01:19 PM   #31
pmclemore
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
This reminds me of a question I have, but never thought to ask:
My escape hatch is at the rear, and has the red handles - I have hesitated to try it, as I worry that a leak will be created where one does not now exist.
Will opening the escape hatch (rear window) cause a leak, or make one more likely?
Thanks - Pat.
And thanks, 2air, for your very important reminders.
pmclemore is offline   Reply With Quote
Old 01-26-2007, 01:31 PM   #32
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by pmclemore
...Will opening the escape hatch (rear window) cause a leak, or make one more likely?.
hi pat...
opening the window will not cause leaks IF you close it after use...
on the modern trailers the exit windows are basically identiical to the full opening classic windows so they can be used for ventilation...
i use them regularly...
what sets the 'exit' windows appart is the screen...
there are little loops of screen piping that when pulled...
release the screen material from its frame...
IF you pull these,
it does take some effort to restore the screen to normal tension,
like rebuilding many window screens...
cheers
2air'
hi pam...
i'm not sure about the exits on a 74.
my 79 had the modern exits but don't sure on a 74...
the exits are/were a federal requirement but what year this started isn't clear 2 me.
check your owners manual OR go around and inspect each window...
exits should have a FULL opening window and a quickly removed screen.
should be on in the back and one on the street side depending on floor plan.
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 01-26-2007, 01:34 PM   #33
pmclemore
pmclemore's Avatar
thanks, 2air. This is a silly thing not to test.
Old 01-26-2007, 04:55 PM   #34
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My Safari's rear window was just a solid piece of glass with no screen. It was only meant to be opened for emergency purposes. For me it was a regular entry point for the vaccum hose from my whole house vac which was in the garage. The window always closed tightly and I used to lube the gasket so that it wouldn't stick when opened. Now my Classic has a screen on its rear window so like noted above you would have to re install that along with the piping that holds it. So far I haven't done that since I know that I'll never get it fitting as tight as it is today.
Jack
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 01-26-2007, 05:16 PM   #35
2airishuman
Profile:
yea u r right jack...
my note only applies to classics, internationals and safaris with the upgrade package...
i forgot about the hehr windows with the rubber/butyl frames used on many of the safaris...
like these...
cheers
2air'
Old 01-27-2007, 06:39 AM   #36
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
Originally Posted by pamelake
Is there an escape window in my '74 Tradewind? How would I know? I have wondered about this.... Pam
Yes, it is the rear window. Cut or kick the screen out and open the window wide, step right down on the rear bumper.
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://travelswithchummy.blogspot.com/
Chaplain Kent is offline   Reply With Quote
Old 01-27-2007, 08:07 AM   #37
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1947 22' Liner
Valley View , Texas
Images: 18
Emergency escapes
It has been nearly 10 years ago that a friend was camped (SOB) at a Park in Concan, TX. Think flash floods. It was nice there along the Frio River, but North of there was a ferocious rain storm. With no warning at about 3:00 AM they felt the trailer move and heard a rush turn to a roar. They were actually floating away in a flash flood. In the dark the trailer rolled 90 degrees to its side, water rushing thru all openings, and all power gone. Luckliy?, they jammed against a huge Cypress tree. They were trapped inside and had no idea as to an emergency escape...probably lucky in this case with the rushing flood and darkness. They survived but the fact remains that they were not prepared at all and neither was the Park where they were safly camped. Know your surroundings, know your emergency exits, have the right equipment and a plan of action
Old 01-27-2007, 08:24 AM   #38
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
What a horrible disaster for everyone involved. I am getting ready to go down to view the lake property after our terrible ice storm. They say it's safe to come down to look now. I'm not sure I want to see if we have any trees left down there. The Argosy was not there thankfully. As far as being able to transport a damaged trailer, my husband talked me in to buying a car hauler by saying that it would indeed be able to haul the Argosy in case of an emergency. He really wanted it for hauling his 52 Ford to shows; however, his ploy worked and we got the really big trailer with axels that would allow us to transport my much loved Argosy out of harms way.
juel is offline   Reply With Quote
Old 01-27-2007, 08:30 AM   #39
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 61
Thank you 2air' for bringing this thread back to life. I have all the required items in my trailer. Fire extigishers, smoke and CO detectors, first aid kit, but no escape plan. We will have one fefore the next trip.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 01-27-2007, 12:19 PM   #40
Fyrzowt
Fyrzowt's Avatar
Images: 8
Melody Ranch's post brings up a good point regarding exit locations. What you may think of as an exit may not be available to you for a number of reasons. Of course our door is our 1st choice, followed by our "emergency exit" window. But don't limit your thinking to these. ANY window that is large enough to fit through can become an exit. Some trailers and MOHOs have skylights. Perfect if the unit is on it's side, kick it out. Above all, preplan.
Don't lock yourself into one way of approaching an emergency.
Dave
Old 01-27-2007, 03:01 PM   #41
2airishuman
Profile:
Originally Posted by Fyrzowt
Melody Ranch's post brings up a good point regarding exit locations. What you may think of as an exit may not be available to you for a number of reasons....Above all, preplan. Don't lock yourself into one way of approaching an emergency.Dave
great point dave and one of the reasons this thread was started...
look again at the pix in post #2...
BOTH doors on the white box trailer are blocked by a big honkin' tree...
all the other windows only partially open except for the official exit window in the slide out...
this family didn't want to 'break' a window to get out after the storm calmed down...
i can understand that thinking; it's how many folks think...
but had there been a fire or gas leak or other slowly building event after the storm calmed...
well waiting for the fire department to arrive and help with the 'exit' should not be the first choice...
in most cases.
and our airstream have safety glass so i'm not sure if it takes more effort to break out a window...
now, after parking/setting up i take a quick look at the ground and surroundings near my exits...
so IF i do need to fall out a window i can anticipate the landing...
cheers
2air'
Important Notice from State Farm! Stefrobrts Insurance & Claims 39 08-06-2008 11:45 AM
Is having the orignal Refrigerator Important? JohnG Refrigerators 9 07-04-2004 05:46 PM
Important upgrade - Cap Puller Janet Exterior Restoration Forum 9 04-18-2004 06:45 AM
What's important to you? yukionna Our Community 8 10-27-2003 05:08 PM
Egress (Escape) Windows hex Windows & Screens 2 12-28-2002 11:08 AM
