Old 12-10-2008, 12:08 AM   #15
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
I have the pop-up blocker on and waving guy is live and well, but it stops the pms from popping up.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 12-10-2008, 12:56 AM   #16
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
What Shari said in post #14, with another "Yes"
Works fine with Firefox.
He's gone.
Old 12-10-2008, 07:46 AM   #17
Jimandrod's Avatar
2008 28' Safari SE
Placitas , New Mexico
Yessssssss!
Yessssssss!!!!
He's GONE!!!!!
Jim & Rod
Air 10899 since 1/06
WBCCI 2484
Jimandrod is offline   Reply With Quote
Old 12-10-2008, 08:17 AM   #18
Crusty's Avatar
1992 34' Excella
Add the line
127.0.0.1 ad.doubleclick.net
to the ...\Windows\system32\drivers\etc\HOSTS file.
You may use Notepad to open and edit this file, but be sure that when you save it that it is not saved as HOSTS.txt, but rather as HOSTS (with no filename extension - it's a Unix thing). If it is saved as HOSTS.txt then rename it to HOSTS
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 12-10-2008, 08:31 AM   #19
Lapeer , Michigan
Crusty I might try that. I just installed stopzilla, rebooted and he is there just the same. How is he getting through several pop up stoppers?
Somebody hold my hand while I go into the registry, it's scary.
Caroljb
photography
Old 12-10-2008, 08:42 AM   #20
Crusty's Avatar
1992 34' Excella
It's a flash video which bypasses html code and the blocker programs which work on it. Those ads are usually crafted, recrafted and rerecrafted to defeat most popup blockers.
The url for the source of the ad (ad.doubleckick.net) is redirected to the local loopback address on your pc by the trick that I mentioned earlier. The flash code is never launched because you've told your pc to look for it locally and it doesn't exist there so nothing happens.
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 12-10-2008, 08:58 AM   #21
Lapeer , Michigan
Thanks Crusty. But I got lost. I typed regedit and now I need the path to windows 32 system file. I thought I knew but I don't.
Caroljb
photography
Old 12-10-2008, 09:14 AM   #22
Crusty's Avatar
1992 34' Excella
Regedit ??? Bad! Very Bad! Close it immediately and don't save any changes if prompted.
Reread my post where I specified the path to the file (except that your drive letter is omitted - I don't know if your system drive is C or D
Browse to the HOSTS file and open with Notepad as I said earlier, add that line anywhere below the last line that starts with a #, save the HOSTS file, and when you save it make sure that it is saved as HOSTS, not HOSTS.txt
This is what my HOSTS file looks like when I open it with Notepad.
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
127.0.0.1 b.casalemedia.com
127.0.0.1 a.tribalfusion.com
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 12-10-2008, 09:18 AM   #23
Lapeer , Michigan
# space.
# For example:
127.0.0.1 localhost
Caroljb
photography
Old 12-10-2008, 09:27 AM   #24
Lapeer , Michigan
I am doing something wrong...
Caroljb
photography
Old 12-10-2008, 09:28 AM   #25
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Correct me if I am wrong but...
I thought the whole point of "Supporting Members" was to get rid of those pop-ups.
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-10-2008, 09:32 AM   #26
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Wheel Interested. Don't use Explorer. It is really a dinosaur.. Go and down load Firefox and you will have no further problems.. It will even import all your favorites from IE for you... Good luck...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 12-10-2008, 09:38 AM   #27
Crusty's Avatar
1992 34' Excella
I don't think you are - that looks like it might be a Windows "Rights" related problem.
Are you logged in to Windows as Administrator equivalent?
Right click on the HOSTS file and select Properties and see if the Read Only box is checked, and if so clear it and try to save again.
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 12-10-2008, 09:39 AM   #28
Lapeer , Michigan
It's vintage Jason.
I'll take it for a spin. I have held out thus far kind of a pain to have to change solely because of the forum though.
Caroljb
photography
New Guy butch e Member Introductions 4 05-01-2007 08:16 PM
New guy needs help Casey Lipe Mechanics Corner - Engines, Transmission & More... 1 09-09-2006 10:42 AM
New guy azblue Member Introductions 4 07-22-2006 07:55 PM
The New Guy swede17 Member Introductions 2 05-09-2006 12:54 PM
