Old 10-17-2008, 06:26 PM   #15
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Originally Posted by bkahler View Post
So how do you turn the a/c on and off? I would think the fan switch on the left would only turn the fan on and not the compressor.
Different controls. See pics above.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-17-2008, 06:48 PM   #16
Interesting. Airstream sure made some changes from 83 to 84. Ours is an 84 310 and has all of the controls combined into one unit.
Old 10-17-2008, 07:45 PM   #17
Mike Leary's Avatar
Images: 11
Pic?........
Old 10-17-2008, 08:01 PM   #18
Sorry about the poor quality of the pictures, I need to find me a better pocket digital camera.
I pulled this unit and a similar one out of a mid 80s dodge ram van. When we first got our 310 it had a bad/broken control unit and I found one on eBay to replace it. Since then I decided it probably wouldn't be a bad idea to have a couple of spares laying around. I think the pick-a-part yard charge $10 each.
Name:	310 dash ac 1x.JPG
ID:	69675 Click image for larger version
Name:	310 dash ac 2x.JPG
ID:	69676 Click image for larger version
Name:	310 dash ac 3x.JPG
I'm going back tomorrow to look for spares for our Argosy motorhome.
Old 10-17-2008, 08:08 PM   #19
Mike Leary's Avatar
Images: 11
Wow! 83 & 84 were different.
Old 10-17-2008, 08:21 PM   #20
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
As for the turn signal lense I wouldn't mind finding a source for those as well.
FYI
i have a new old never used complete light assy that can be had for $12 plus ship . had to replace one on my 84 310. also have a power seat slide with the switch new never used for $ 100. plus shio. been laying in my storage shed for 5 years. any interest call 256 882 6664 . im not a dealer just a retired army dude.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 10-17-2008, 10:19 PM   #21
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The fan switch is a standard GM part. I'll give our kid a call tomorrow (he works for a very large Chevy dealership), and see if it's available. If not, second best is your local NAPA, they might have the switch available separately. It's pretty much the same switch used in similar year pickups and vans.
As for the scare light, do you need the lens or the whole unit? I know there are a bunch of the lenses in the stock room, I counted them yesterday.
Old 10-18-2008, 07:56 AM   #22
Mike Leary's Avatar
Images: 11
Thanks, Terry, I'll call on Monday, it's just the plastic cover I need on the light.
Old 10-18-2008, 09:52 AM   #23
Well Preserved
1993 21' Sovereign
Mike, I just talked to our kid, and he says there is a casting number on the back of the housing for the fan control. He needs that number to make sure he is looking up the right thing, what you have could have been in a parts bin for a while before they installed it. We don't want to assume it's an '83 switch just because the coach is an '83. If you can access the back of it, the number should start with something like "172", and be really long.
Old 10-18-2008, 09:54 AM   #24
Mike Leary's Avatar
Images: 11
Will pull it, Thanks.
Old 10-18-2008, 10:29 AM   #25
Mike Leary's Avatar
Images: 11
Curious, seems to me our early trailers had glass lenses, or have they always been plastic?
Old 10-18-2008, 02:38 PM   #26
Mike,
I picked this control unit up at the pick-a-part this morning. I believe it is the same unit as you have in your motorhome. The casting # is PT-339829 C-2. The only markings I can find on the switch itself is INDAK.
ID:	69770Click image for larger version
ID:	69772 Click image for larger version
If only your switch is bad you might be able to remove it without removing the whole assembly. The switch is held in place by 2 phillips head screws. You might be able to use a stubby screw driver to reach up in there.
Old 10-18-2008, 02:45 PM   #27
Mike Leary's Avatar
Images: 11
Mike. The switch is held in place by 2 phillips head screws. You might be able to use a stubby screw driver to reach up in there.
That is very helpfull, thanks Brad.
Old 10-18-2008, 02:46 PM   #28
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Wonder if Andy will ever post here since it's titled InlandRV...???????
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Need wheels? - do it at InlandRV doh Wheels, Hubs & Bearings 0 02-28-2004 09:52 PM
