Old 04-28-2009, 09:14 PM   #1
Lothlorian's Avatar
Loganville , Georgia
I inherited a 20' pontoon boat
I inherited a 20' X 8' pontoon boat with a 35 hp evinrude outboard. I am trying to figure how to move it from upper Wisconsin to Southern Illinois. I have a 13' X 6' landscape trailer which was made in the 60's. It was made from very thick angle iron and has 1 axel which can hold 3800 lbs. Pontoon boats made the same size as the one I inherited weigh about 1250 lbs. I am trying to figure out if I can do something to the trailer so I can carry it home. The rails come off the trailer and the landscape cage door in the back comes off. I can make the trailer flat and put landscape ties sideways to hold the pontoons.
I have been looking for a pontoon trailer to rent. I am just trying to figure out if it is worth me getting it. I really want to get it. Anybody have any ideas. It does not have a trailer.
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 04-28-2009, 09:20 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
every pontoon boat in America will be coming off their trailers for the summer in the next couple weeks, why not borrow/rent one of those? If you are going to keep it in a slip, ask around the Marina. BTW, which lake in SI?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-28-2009, 09:24 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Brian & Adrienne!
My suggestion would be to try contacting the Marina's found at each of the larger lakes in Southern Illinois. I suspect that you may be able to rent the appropriate trailer more economically than to make the changes on your landscaping trailer. Based upon what I see of pontoon trailers around here, most for a rig the size of the one that you want to transport have a single axle.
Good luck with your deliberations!
Kevin
P.S.: Once in a great while, a pontoon trailer will be offered for sale in the local trader publications for a very reasonable price.
Kevin D. Allen
AIR #827
Old 04-28-2009, 10:29 PM   #4
Images: 59
You'd be better off using your utility trailer. Make sure you pack the bearings and have good tires.
I wouldn't use a rented or borrowed pontoon trailer because most of them are just storage trailers and only get used twice a year. You don't want to be stuck in Rockford with a blown tire or a smoked bearing on someone else's trailer.
Airstream Pontoon rig???? AIR-Quarius Off Topic Forum 8 12-30-2007 10:00 PM
Inherited WBCCI Numbers - Info Please? :) krikles WBCCI Forum 6 10-16-2007 11:16 AM
Just inherited a 1964 24ft land yacht fzgrab Sinks, Showers & Toilets 5 09-02-2006 10:24 AM
Inherited Caravelli (?) - Need Advice Karen R Towing, Tow Vehicles & Hitches 22 10-13-2004 05:51 AM
portable boat? kent osborn Off Topic Forum 23 07-11-2004 01:01 PM
