Old 03-31-2009, 11:03 PM   #1
CanoeStream's Avatar
St. Cloud , Minnesota
I didn't think
My '06 was built in the unlubed bearing period when Airstream installed higher capacity Dexter axles for a few months. I think my GAWR is about 7200#. Tongue weight doesn't count against that, so I thought I had leeway to break the mold. Am I mistaken?
This picture shows my Safari tilted to the left. Towing is getting to be a real "Hey, watch this!" experience.
I got a great deal on a 1925 wood cookstove. The aluminum color and nickeled steel fittings seemed an Airstream natural, so I thought, "What could go wrong?"
Name:	Safari Stove.jpg
I installed it in place of my roadside couch. It's over the axles so no rear end separation could happen. Wait. This gets good. I've re-routed the flue to the stack in the adjacent Dometic, so I have the first tri-fuel fridge in which wood is used. That's not really working yet but there's a more immediate issue.
Our Safari tilts to the roadside too much. Above 110 pounds pressure the tires look like something from Roger Rabbit. Anybody ever use airbags on just one side? The stove already adds almost 500#, so I'm not wanting to carry all my firewood on the curbside. Here's my best idea and the real question -- on the WD setup, how about 1000# springbars on the left and 500# springbars on the right? Has this been done before?
I won't even start in on what's happening with the outriggers...
5 meter Langford Nahanni
Old 03-31-2009, 11:11 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Nice stove!
Have you checked your running gear? So long as it's properly aligned and the tires are perfectly inflated, you should be fine....
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 03-31-2009, 11:48 PM   #3
Images: 59
Bob,
I think if you took the bread keepers off the top you could move the thing closer to the wall.
Then it would be a simple matter to add a tag axle, just on that side, to take some of the weight. Or you could add a set of leaf springs on top of the torsion axle and increase it's capacity that way.
And I wouldn't put a 1000# bar on one side and a 500# on the other. It's much easier to just saw halfway through one of the bars to reduce it's rating.
. . . the moderators are sure up late tonight. Party is called off until they turn in.
Old 04-01-2009, 12:19 AM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
...And you did all this just today, Right?...
I'm going to go to the basement and let my Janitor in a Drum out...
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 04-01-2009, 05:07 AM   #5
silverhawk's Avatar
1964 22' Safari
Elyria , Ohio
Images: 20
Send a message via Yahoo to silverhawk
Goood Idea.
silverhawk is offline   Reply With Quote
Old 04-01-2009, 05:41 AM   #6
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Drop your tire pressure 30# on the passenger side of your TV. It will straighten the entire rig out (Airstream tiled left, TV tilted right).
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 04-01-2009, 06:39 AM   #7
1983 31' International
Belle Fourche , South Dakota
Stack your fire wood on the opposite side. When it starts tilting back to the other side it's time to come home.
310astream is offline   Reply With Quote
Old 04-01-2009, 07:11 AM   #8
1994 30' Excella
Mississauga , Ontario
April fool!!!
Nice one Bob.
Just put all the firewood on the other side.
Al
BigAl is online now   Reply With Quote
Old 04-01-2009, 07:28 AM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
This is an April Fool's thing, right? Sometimes it's hard to tell.
I know there is a fireplace out there on the market that has been put in a few ASs. Originally designed for yachts.
Old 04-01-2009, 07:35 AM   #10
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
This is spot on serious. Let's not assume everything on 4/1 is a joke.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 04-01-2009, 07:45 AM   #11
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Bloomington , Illinois
Do you store your cast iron skillets in the oven? That could be part of the tilting problem? We keep the cast iron we travel with in the credenza on the opposite wall from our oven.
nancy mac
maccamper is offline   Reply With Quote
Old 04-01-2009, 08:40 AM   #12
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I counter balanced mine with the cast iron, claw foot tub on the opposite side.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-01-2009, 09:11 AM   #13
funkill's Avatar
reno , NV
Images: 27
Did you check to see if the witch is still in the oven? Maybe you could stack her on top of the firewood - or have her mix a spell to lighten the curb side load?
funkill is offline   Reply With Quote
Old 04-01-2009, 09:34 AM   #14
1963 24' Tradewind
San Diego , California
Maybe you can find another deal on a 1925 wood cookstove, put in on the other side and you will have a double cook top to feed us all. Proplem solved!!
Sixty3TW4US is offline   Reply With Quote
