Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
View Poll Results: How strong was your password?
PASSED: With flying colors 9 64.29%
FAILED: Wide Open like a barn door 2 14.29%
Half Passed: Anyone can guess it~ 3 21.43%
Don\'t know or, use passwords 0 0%
Voters: 14. You may not vote on this poll
Old 05-12-2003, 03:12 PM   #15
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Thumbs up verbatim
eric
Are you sure of the 165mbs? That is higher than most fortune 50 companies.
I have a very robust connection and I am at 1.64mbs per second.
Moreover, to get those kinds of speed you would either need to be working on an Internet backbone, a huge ISP, at a job that has lots of money and dedicates it to extremely high web connections, or you are independ weathy and have between 107 and 108 T-1 lines.
Who did you use to run the the test?
I ran the test this morning using:
Bandwidth speed test
Just copied and pasted the results.
I believe they had a major hic-up this morning..lol
I didn't believe it either but, it sure impressed me..
Just re-ran it at 522pm.
3.1 megabits per second
Run the test again Discuss in the forum
Details
Your raw speed was 3072634.84 bits per second which is the same as:
Communications
How communication devices are rated. Kilo means 1,000 and mega means 1,000,000. Examples include 56k modem and 10Mbit Ethernet
Storage
375.1 kilobytes per second
The way data is measured on your hard drive and how file sharing and FTP programs measure transfer speeds. Kilo is 1,024 and mega is 1,048,576.
1MB file download
2.7 seconds
The time it would take you to download a 1 megabyte file at this speed.
Rating
Compared to all connection types worldwide, yours is fantastic
This is abt my average result day in and out. Sometimes higher and, more often..lower
53flyingcloud is offline   Reply With Quote
Old 05-12-2003, 07:41 PM   #16
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
That's pretty truley amazing speed!
1024 kilobytes = 1mb though
True 1000 is kilo and 1,000,000 is mega however once you place the kilobyte after 1000 that's 1000 kilobytes or 1000 thousand bytes which is now a megabyte.
1,048,576 kilobytes I believe would be a gigabyte since that is 1,048,576 thousand bytes.
There are 8 bits per byte.
So if you have 3072634.84 bits per second you need to divide that by 8 and you then divide that by 1024(1mb) which in fact you were getting 3.1mb per second which is still very incredible! The most I get is a bit over 1.54mbs.
I could be wrong, but on our networks 1024k =1mb
Here is another way to look at it....when you download files, you see 699kb, 79kb, 89kb, 999kb then it goes 1024kb which then you see it start 1.1mb, 1.2mb, 1.3mb. This is because after 999kilobytes you then get into megabytes.
Eric
Old 05-13-2003, 05:48 AM   #17
53flyingcloud
Thumbs up just stating the facts
eric
Here is a tip I picked up..It might not work for you but..
This tweak is for broad band cable connections on stand alone machines with WinXP professional version - might work on Home version also. It may also work with networked machines as well.
This tweak assumes that you have let WinXP create a connection on install for your cable modem/NIC combination and that your connection has tcp/ip - QoS - file and print sharing - and client for Microsoft networks , only, installed. It also assumes that WinXP will detect your NIC and has in-box drivers for it. If it doesn't do not try this.
In the "My Network Places" properties (right-click on the desktop icon and choose properties), highlight the connection
then at the menu bar choose "Advanced" then "Advanced Settings". Uncheck the two boxes in the lower half for the
bindings for File and Printer sharing and Client for MS networks. Click OK.
From the Windows XP CD in the support directory from the support cab, extract the file netcap.exe and place it in a
directory on your hard drive or even in the root of your C:\ drive.
Next, open up a command prompt window and change directories to where you put netcap.exe. then type "netcap/?".
It will list some commands that are available for netcap and a netmon driver will be installed. At the bottom you will
see your adapters. You should see two of them if using a 3Com card. One will be for LAN and the other will be for
WAN something or other.
Next type "netcap/Remove". This will remove the netmon driver.
Open up Control Panel->System->Dev Man and look at your network adapters. You should now see two of them and one will have a yellow ! on it. Right-click on the one without the yellow ! and choose uninstall. YES! You are uninstalling your network adapter, continue with the uninstall. Do not restart yet.
Check your connection properties to make sure that no connection exists. If you get a wizard just cancel out of it.
Now re-start the machine.
After re-start go to your connection properties again and you should have a new connection called "Local area connection 2". Highlight the connection, then at the menu bar choose "Advanced" then "Advanced Settings". Uncheck the two boxes in the lower half for the bindings for File and Printer sharing and Client for MS networks. Click OK.
Choose connection properties and uncheck the "QOS" box.
Re-start the machine.
After restart enjoy the increased responsiveness of IE, faster page loading, and a connection speed boost.
Why it works, it seems that windows XP, in its zeal to make sure every base is covered installs two separate versions of the NIC card. One you do not normally see in any properties. Remember the "netcap/?" command above showing two different adapters? The LAN one is the one you see. The invisible one loads everything down and its like your running two separate cards together, sharing a connection among two cards, this method breaks this "bond" and allows the NIC to run un-hindered.
ciao
Old 07-31-2003, 02:53 PM   #18
canny_banjo_man
canny_banjo_man's Avatar
Profile:  Yorkshire , England
Oh 'eck...!!!
Say '53...& S/Twinkie....
What kind of language is that U both talkin, is it LOCAL slang or upper tosh slang ???, well thinkin abt it, if I can't understand it...it DON'T concern me...lol
There are 8 bits per byte...yep sounds like eating a FISH FINGER....( U did'nt kn fish had FINGERS...well they DO in England...)
Eric, if people call U strange, politely remind them that U r NOT strange, jus DIFFERENT, an when Yr doctor asks U "How did U find Yrself this morning"...U jus reply..." Oh I jus pulled bk the bed clothes...and there I were...)... he'll kn which one U mean...
'53, if U can follow this, U r a real smart COOKIE...lmao,
O K Guys, stay kewl...Chris.... .
It's NICE 2B Important...but it's more Important 2B NICE...Chris.....
canny_banjo_man is offline   Reply With Quote
Old 07-31-2003, 03:11 PM   #19
53flyingcloud
Chris
The world is filled with much, much smarter folks..What counts is how it's used.
You have found a nich in making people "smile" at themselves..That takes a rare quality in a person..
ciao
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
Original 2 prong cord, how do I make it safe? Jabba Electrical - Systems, Generators, Batteries & Solar 19 03-20-2005 04:48 PM
Kitchen drawers-can they support weight? femuse Cabinets, Counter Tops & Furnishings 7 10-29-2004 06:13 PM
which A/S will work with my Jeep Grand vajeep On The Road... 19 02-19-2004 09:47 PM
Safe from Lightning in an Airstream? maggieairstream Our Community 21 07-22-2003 04:18 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
