Old 09-22-2011, 06:51 PM   #15
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
Avions......
Just to keep this AVION thread going.These are neat trailers,I wish there were more photos info out there,I guess its our job.
Here's a pic of my 32S
Airline is offline   Reply With Quote
Old 09-22-2011, 07:05 PM   #16
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Cool pic...
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 09-22-2011, 07:34 PM   #17
Airline's Avatar
1972 29' Ambassador
Avion
Thanks Silverwanabe
I just started a thread on this site for AVION Trailer Pictures.
If you guys have any pics with any other info about the trailer,I think this might be a useful thread.
Old 07-27-2012, 04:28 PM   #18
Deerfield Beach , Florida
After seeing the photos of the Avion going through the pot hole I'd like to know how you'ld change a tire on the road?
ConchyCamper is offline   Reply With Quote
Old 07-27-2012, 08:28 PM   #19
Kevin245's Avatar
Our Avion utilizes the MOR/ryde suspension which performs very well. With a tandem axle rig we pull the good tire up on lynx blocks to raise/unload the bad tire. I keep a small service jack in the TV to aid in lifting affected axle up an additional amount since the system is semi independent. Then remove the affected tire assembly. Avion also provided chain straps to hold an empty axle up for towing in the event you had to remove a wheel and had no spare to install in its place.
Eleanor Roosevelt
Old 07-28-2012, 06:22 AM   #20
Thanks Kevin,
Will a 10 pak of Lynx be enough to see me through with my MOR/ryde tandem?
Al
Old 07-28-2012, 07:08 AM   #21
On the 250 mile ride home from the PO I lost the inside tread (about the first 1 1/2") on the curbside front. The Towmasters are old and checked between the treads and not the sidewalls which I thought strange.
We are getting new tires either way, but I would like to know is there a simple way to check this MOR/Ryde system for alignment and other factors that could have caused this.
Al
I've trailered many a boat in my day and realize it was most likely the old tire but I want to make sure so I don't ruin the new ones.
Old 07-28-2012, 08:22 PM   #22
Kevin245's Avatar
Thanks Kevin,
Al
Al, I have a 10 pack and the quantity is marginal. I plan to add another 10 pack to my gear for our Fall trips.
Eleanor Roosevelt
Old 07-28-2012, 08:38 PM   #23
Kevin245's Avatar
Al
You may be able to get some tech advice on alignment from the www.silveravion.com site, or possibly MOR/ryde. Ours had a suspension carrier weld failure to the frame rail that caused a negative camber of the steer side wheel set. We had a local welder fix after the tires were removed and the suspension carrier was pulled back into its original position. I expected odd tire wear afterwards but there was none.
Barring any special equipment I would make up a straight beam and offset pointer tool to confirm wheel alignment (toe in/out, and camber. Simple hand measurements can be a highly effective way to measure alignment parameters.
Eleanor Roosevelt
Old 12-07-2012, 08:49 PM   #24
blue point , New York
Just purchased 1970 avion 21 ft with twin axel .seems to be a nice setup.almost the same as tractor[tractor trailer] suspension.looking for factory awning [complete] thanks
sillyrubb is offline   Reply With Quote
Basic exterior cleaning of a neglected trailer Andy R Cleaning, Stripping & Polishing 12 05-10-2013 11:03 AM
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
2002 Classic 25' suspension? Kistler 2001 - 2005 Classic 7 11-12-2002 01:01 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
