Old 08-17-2015, 06:12 AM   #1
Twinke58's Avatar
1958 26' Overlander
Kansas City , Missouri
How can I get my tire covers clean?
I'm cleaning my tire covers and I used dawn dish soap and warm water with a brush. It's still a little dirty but I got it 95 percent clean. Does anyone no how to get it cleaner?
Name:	ImageUploadedByAirstream Forums1439813390.835966.jpg
ID:	245654one I cleaned and the other is dirty. Both are clean now.
Sent from my iPhone using Airstream Forum
Twinke58 is offline   Reply With Quote
Old 08-17-2015, 06:18 AM   #2
Lily&Me's Avatar
Normal , Illinois
Repeat what you did, adding oxyclean to your hot water and Dawn.
Use a good brush, rinse thoroughly.
Maggie
Old 08-17-2015, 07:13 AM   #3
Twinke58's Avatar
1958 26' Overlander
Thanks! I'll try that!
Old 08-17-2015, 10:07 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
As noted above, with a power washer rinse.
Old 08-17-2015, 10:10 AM   #5
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Buy new ones, not that expensive.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 11-17-2015, 02:23 PM   #6
Herndon , Virginia
What Do Tire Covers Accomplish?
We are new AS-er's with about a year's experience towing and camping with our 27' AS Intl Serenity and an F150 Platinum 6.2L V8. Delighted with the trailer and the truck and eagerly awaiting the spring -- here in N Va., temps too cold to risk frozen plumbing, so the trailer's winterized and parked securely at a local RV storage yard.
My question for the forum is -- we are careful with trailer tires -- frequent pressure and lug nut checks, bearing and brake checks. I have seen tire covers used in 2 instances. First, where RV's are long-term parked in multi-month, multi-year position; and second, all the time, by overnighters and short-stayers. I expect tires to wear and wear out more frequently, and plan to replace before they're seriously worn -- on the order of every 2-3 years or more frequently. What do I gain (other than satisfying my mild compulsive instincts for trailer perfection) by covering the tires during winter storage? I would feel differently if I didn't plan very frequent use (2-3 trips/month) between March and November of each year. Tires get longest life from care and routine use, and suffer most from long-term outdoor exposure. I know the covers are pretty inexpensive, but are they overkill? Opinions pls. cb
66coupe is offline   Reply With Quote
Old 11-17-2015, 03:08 PM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I do not let mine get that bad before cleaning. A light spray of bleach and water and wipe down with a brush keeps them looking new.
MICHAEL
Old 11-17-2015, 03:34 PM   #8
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
I've used white wall cleaner in the past.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 11-17-2015, 03:42 PM   #9
2011 30' Flying Cloud
Greenback , Tennessee
Buy black ones! They also look better with aluminum.
Gneiss Guy is offline   Reply With Quote
How do I get new holding tank covers/ belly pans? Mixter Belly Pans & Banana Wraps 6 11-08-2012 09:13 PM
Vent covers and outside propane covers robwok 1960 - 1964 Overlander 4 02-09-2011 11:56 AM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 03:34 PM
Can I still get rims with "moon" covers? PhilMateo Wheels, Hubs & Bearings 11 11-20-2007 06:22 AM
Rated tire speed - Can I get faster than 62? Goin camping Tires 1 09-25-2006 05:29 AM
