Old 02-07-2017, 07:40 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Home thermostat
As many of you spend a considerable amount of time on the road I thought this would be an appropriate place to post my question on home thermostats.
I am looking to upgrade our thermostats so that I can control them on the road and was wondering which ones you all would recommend?
urnmor is online now   Reply With Quote
Old 02-07-2017, 07:51 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
When I had my system replaced they installed the WiFi thermostats from Trane and a Nexia hub. The hub connects via Ethernet cable to my router and the thermostats talk to the hub via WiFi. I have an App on my iPhone and iPad and you can also get to it via a web site from any browser. The setup allows me to store "automations" that are basically scripts that the system sends to the thermostats. I have one for "AWAY", one for "OFF" and one for "OCCUPIED". I have a schedule in each of the thermostats. OCCUPIED runs the schedules, AWAY sets the thermostats on heat at 55 degrees to keep pipes from freezing and OFF turns everything off.
I can run automations or control individual thermostats from the apps.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-07-2017, 08:02 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I installed a Sensi WiFi by Emerson which lets me monitor and control my home via my smartphone. It is fully programmable, but I just keep an eye on the temperature and make adjustments as we near home.
Richard
azflycaster is online now   Reply With Quote
Old 02-07-2017, 08:09 AM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I have used NEST, Honeywell, but I now have Ecobee, which I like the best of all of them. Sort of depends on your equipment at home as to which may be best for you.
Larry
lsbrodsky is offline   Reply With Quote
Old 02-07-2017, 09:37 AM   #5
dznf0g's Avatar
Oswego , Illinois
I've been using NEST for several years. No problems nor complaints. Also have a
Nest AWARE and a Nestcam.
-Rich-
Old 02-07-2017, 09:42 AM   #6
2017 27' Flying Cloud
London , Ontario
Also have had a Nest for many years, since they came out. Love it. Also now have two Nest smoke detectors (also love them, particularly the nightlight feature) and two Nest cameras, one inside, one outside. High quality stuff.
Philip Jones is online now   Reply With Quote
Old 02-07-2017, 11:26 AM   #7
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
We had a non-wifi programmable thermostat for years, and replaced it with a basic Honeywell wifi unit this last year. The Honeywell is programmable at the thermostat just like a non-wifi model, which we like. The wifi app gives similar controls, plus more flexibility for programming the schedule.
Our model is Honeywell's basic version. One thing we wish we had that comes with more advanced models is the ability to know if the heating/cooling is actually on at any given moment, and a record of how many hours & minutes of heating and cooling has been run. That lets you know more about what is actually happening when you are gone.
SSquared is online now   Reply With Quote
Old 02-07-2017, 05:01 PM   #8
Rg416's Avatar
2017 22' Sport
Cohasset , Massachusetts
I have a Nest thermostat in each of our two zones. I really like them. I also have a Nest Camera to keep an eye on things while we're away. I can see the set temp, change it, see humidity, even see outdoor temp remotely. I can set it for a more efficient 'Away' setting, and it will actually notice if there's no movement in the room for some time and set it to Away on its own if I forget. The thermostats and camera are all visible and controllable via the Nest smartphone app.
The only thing I'm not crazy about is Google now owning Nest, as their privacy policy is, well, no privacy. They claim to not use any data from Nest, but who can trust them? I picture Google executives sitting around saying, "Look, Rich just turned up his heat! Let's put some down coat ads on his browser page." ;-/
Rg416 is offline   Reply With Quote
Old 02-07-2017, 05:26 PM   #9
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
Also use the Ecobee and like it a lot (disclosure, I work in the HAVC industry)
Easy to use, reads the outdoor temperature via you zip code from the web, so that can simplify some set up. And mine doesn't have geofencing that may seem like a privacy invasion to some.
Nice when you know you are coming home a day early from a long trip. Just pull out your phone and start up the AC from vacation mode to standard program. It also has 365 day programming.
Generally speaking, you will probably be fine with any of the major brands and their units. Important to get the one you will USE the PROGRAMMING. If you don't like it or understand how to use it, move onto another product.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 02-07-2017, 05:26 PM   #10
2015 30' Classic
Pleasanton , California
I have two Nest thermostats that are easily controlled from the smartphone while on the road. I also run Home Assistant, this is a home automation hub that's based on a Raspberry Pi 3 computer (RP3). A RP3 cost about $40 and the software is open source and free. In my case, I use Home Assistant for many things. As an example, it acts as my home alarm. When I arm the system from my phone, it automatically sets my Nest thermostats to Away mode (saving energy) and will sound an alarm if any of my doors are opened. if an alarm goes off, Home Assistant will automatically notify me on my phone. I probably use Home Assistant for another 5 things so it's great for folks who are into home automation and can write simple scripts.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 02-07-2017, 06:15 PM   #11
AirDFW's Avatar
2016 27' International
Dallas , Texas
Ecobee is great
AirDFW is offline   Reply With Quote
Old 02-07-2017, 06:18 PM   #12
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
nest here too. I have the nest cam watching my reef tank.
DoublTrouble is offline   Reply With Quote
Old 02-07-2017, 07:16 PM   #13
urnmor's Avatar
Berlin , Maryland
My thanks to all a lot of great info Now I need to talk to my AC guy.
Old 02-07-2017, 07:18 PM   #14
Lost in America
mojo's Avatar
2004 19' International CCD
Oak Creek , Arizona
Interesting news story on how hackers can get into your phone and computer through Wifi thermostats and refrigerators. Google it.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Home Sweet Home deauxrite Upholstery, Blinds, Walls & Interior Finishes 7 11-19-2017 10:23 AM
Home away from home :: 2003 Airstream Safari fman88 Airstream Registry Discussions 0 09-14-2011 05:54 PM
Our Home Away From Home Bobz Hog 1968 Overlander 34 09-05-2009 11:24 PM
A home away from home drjudy Member Introductions 8 10-31-2007 04:58 PM
