Old 02-07-2017, 07:46 PM   #15
2015 30' Classic
Pleasanton , California
BTW the Nest is very easy to install and comes with everything you need - including a screwdriver. No A/C repairman required.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 02-08-2017, 05:45 AM   #16
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Kwhat can't they get into today. It seems like every electronic item we own is hackable. Not sure what the solution is other then to live off the grid
urnmor is offline   Reply With Quote
Old 02-08-2017, 07:25 AM   #17
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
I control my thermostat via my DSC alarm system over the telephone. I can select programmed thermostat modes ie. home and away, check settings, change temp etc. If the furnace stops working or temp goes below 6 degrees Celcius it notifies the alarm company. Alarm also has other monitors for wet floors, sump pump overflow and gets me an insurance discount for flood and more. I can turn off and on the alarm system and open a garage door to let someone in. Internet not needed. Peace of mind while away and up to room temperature by the time I arrive home.
TRIPPPIN is offline   Reply With Quote
Old 02-08-2017, 07:29 AM   #18
Rg416's Avatar
2019 22' Sport
Cohasset , Alaska
Yes the Nest is very easy to install yourself. Everything you need is included. There are videos to walk you through it as well.
Rg416 is offline   Reply With Quote
Old 02-08-2017, 09:27 AM   #19
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
I just read in a security brief that hackers are now hacking home WiFi's in addition to anything else they can get a hold of.
They encouraged a separate lengthy password for each appliance or functioning item that you controlled by WiFi.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 02-08-2017, 10:37 AM   #20
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
New thermostats may require new wiring
We actually bought a Nest a couple years ago, before our Honeywell. We found out that it required running a new multi-wire cable down to the furnace. We were going to do that ourselves, but the Nest warranty statement said the unit would not be covered unless an approved installer ran that wire. That caused us to return the Nest. The Honeywell also needed the new wire, but their warranty did not have such a restriction.
I don't remember numbers for sure, but I think our original thermostat cable had six wires and the new requirement was seven.
SSquared is offline   Reply With Quote
Home Sweet Home deauxrite Upholstery, Blinds, Walls & Interior Finishes 7 11-19-2017 10:23 AM
Home away from home :: 2003 Airstream Safari fman88 Airstream Registry Discussions 0 09-14-2011 05:54 PM
Our Home Away From Home Bobz Hog 1968 Overlander 34 09-05-2009 11:24 PM
A home away from home drjudy Member Introductions 8 10-31-2007 04:58 PM
