This is a copy of one of the forms used to report..
I used this because it was easy to do over the internet...
it's blank on purpose
American Meteor Society -- Fireball Reporting Form
This form is intended to be easy to fill out for anyone who has seen a fireball. Your report is important, it alerts us to potentially scientifically significant events that occur, and contributes to the general database of knowledge about meteors. Please provide as much information as you can, any items you cannot fill in, leave blank. We will contact you if we have any follow-up questions. Please note that summaries of your data will be published on our website, including your name and location of observation. If you wish to keep anonymous please supply only your first name. As for location, the nearest town will suffice, even if it lies many miles away. We will contact you if exact locations are needed.
Contact Information
Observer's name:
Observer's e-mail (required):
Address:
Phone (home): Phone (work):
Date of Occurrence
Please enter what we call a "double date", i.e. if you saw it before midnight on the evening of August 11th, the double date would be August 11-12. If you saw it early on the morning of December 14th, the double date would be December 13-14. This avoids ambiguities in what day it happened. Please include the year.
Date (required):
Time of Occurrence
Time (required): AM PM 24 hour clock
Time Zone:
UTC Eastern Central Mountain Pacific Alaskan/Hawaiian
Other (Specify)
Standard time or daylight savings time? Standard Time Daylight Savings Time
Observation Location
Please give both the name of the location and geographic coordinates if at all possible. If you do not know them, describe the location in reference to nearby cities or towns, or prominent landmarks. Please do not use local or ambiguous descriptions.
Location Name (required):
If possible, provide the geographic coordinates of the observation location.
Latitude - deg, min, sec (or decimal form):
Longitude - deg, min, sec (or decimal form):
How bright was it?
Standard stellar magnitude scale:
If you're not familiar with the stellar magnitude system, use one of the following:
As bright as Venus
Brighter than Venus but dimmer than the 1st quarter moon
As bright as the 1st quarter moon
Brighter than the 1st quarter but dimmer than the full moon
As bright as the full moon
Brighter than the full moon
As bright as the Sun
Brighter than the Sun
How long did it last?
Duration (in seconds):
If you're not sure, use one of the following estimations:
Less than 1 second
1 - 2 seconds
2 - 5 seconds
5 - 10 seconds
Greater than 10 seconds
What color was it?
Color:
In what direction did you FIRST see it?
Initial Azimuth (bearing) in degrees:
Azimuth Type: Magnetic True
If you are not familiar with determining azimuths, indicate one of the following:
Directly overhead
North
Northeast
East
Southeast
South
Southwest
West
Northwest
I'm not sure
How far above the horizon was it when it first appeared? If it appeared above an elevated horizon, please estimate the height above where the true horizon would be.
Initial Altitude in degrees:
In what direction did you LAST see it?
Final Azimuth (bearing) in degrees:
Directly overhead
North
Northeast
East
Southeast
South
Southwest
West
Northwest
I'm not sure
How far above the horizon was it when it last appeared? If it appeared above an elevated horizon, please estimate the height above where the true horizon would be.
Final Altitude in degrees:
Did it pass directly overhead?
Yes No
Was there a persistent train (trail) associated with it?
Some fireballs leave smoke trails or glowing "trains" after the fireball has disappeared. Did this object have one? If so, describe it as best you can.
Did the object leave a train? Yes No
How long did it last? seconds minutes
What color was the train?
How long was the train (in degrees)?
If you checked "yes" to the above, please describe the details of the train, such as whether you thought it was a either a smoke trail or a glowing train, and any changes that occurred to the train over time. unable to tell as it struck my house by falling from the skies~!!
Was this fireball a bolide?
A bolide is a fireball that ends its visible flight in a bright terminal flash (explosion).
Did you see a terminal flash with this fireball? Yes No
If you checked "yes," please describe the details of what you saw.
only in the sense that it landed in my backyard and I have it..
Were there sonic effects associated with it?
Some fireballs will have sounds (sonics) associated with them, divided into two types: (1) those sounds which are heard concurrently with the fireball observation (called electrophonic sounds), and (2) those sounds which are delayed, usually occurring within a few minutes after the observation (these can be sonic booms or terminal burst booms).
Did you hear any concurrent sounds associated with this fireball? Yes No
Did you hear any delayed sounds (booms) associated with this fireball? Yes No
If you checked "yes" to either of the above, please describe the details of what you heard. If the sounds were delayed, please include your best estimation of the length of time between the fireball and the sounds, and the time interval between successive booms.
I heard the noise as it struck my house..
Remarks
Place any remarks or additional information you feel is important here:
I have this meterorite in hand..i have only touched it once..it's now covered in plastic box
Thank you for taking the time and initiative to submit your data.
Last updated on 06/7/06
