02-12-2017, 07:36 PM
Delta
Helicopter Lift
Has anyone or know of anyone that has lifted an airstream via helicopter. I would like to place one in the back part of my lot. The wow factor being how did this get here.
( it's cheaper that putting in a road)
I have an idea how to rig it but just wondering if there are any pitfalls with doing it.
Don
02-12-2017, 07:47 PM
Remember, Safety Third
Catfish Corners
, Georgia
Subscribed. This should be interesting.
02-12-2017, 07:53 PM
Delta
Flying air streams there will be video
02-12-2017, 07:57 PM
1989 34.5' Airstream 345
Ebro
, Fla Panhandle
I would think a large crane would be able to do the job if access is possible to get into the right spot.
Probably cost less than a helo lift, Not as exciting either
How ever you lift it, make sure they use wide spreaders on the straps to avoid crushing loads on sides and roof.
Will need video of how ever you do the job.
One thought to consider , is that once you start using it you may want to take it on the road.
Good luck in getting it where you want it.
Cheers Richard
1969 25' Tradewind
Shasta Lake
Back in the day of the Wally caravans they loaded Airstream's onto ships by rigging under the tires and a line to the tongue they would lift from those points.
Do a search for the caravans and you might find pictures of this.
02-12-2017, 08:03 PM
2019 27' Flying Cloud
Kansas City
, Missouri
I work in the HVAC field. We have air conditioning units that are lifted to building rooftops.
We typically only use a helicopter to lift if locations prevent reaching by crane. I suggest checking out crane yards in your area first for a quote. A crane would be most likely a 4 hour minimum, and additional costs incurred to move any utility lines or other problems with egress. There may be municipal requirements as well.
Piggy Bank
02-12-2017, 11:38 PM
Walnut Creek
not a good idea
When you mentioned road, it sounds like the distance is not simply at the back of a city lot as would be an application that a large crane could handle. Therefore the helicopter is needed.
It is likely possible, but difficult. As mentioned, air conditioners are lifted when time is an issue. A fellow used a helicopter to deliver concrete, because the distance as the crow flew was considerably less difficult and shorter than the road to his house.
However, an AS will weigh enough to require a larger bird and the rigging will need to be more complex than what would be required for an air conditioner. Something like the skids used to carry military vehicles and a secure tie down system. Contacting a lifting service to discuss options is not a bad first step.
It really sounds more difficult than the shock value is worth and the coach would likely be lost to future use. Consequently, not proceeding seems to be the advisable coarse of action. A tiny house built in sections that are easily transported might be a better solution. Pat
02-13-2017, 04:02 AM
1982 31' Airstream 310
champaign
http://granddaddy.co.za/
They lifted Airstreams onto the rooftop of this hotel. Don't know how they got em up there but might be worth investigating.
02-13-2017, 05:43 AM
2016 23' International
Centennial
I have wanted to do this for years and will follow this thread. I built a huge pond in my back yard and would love to have an Airstream office where I could go out there to work and watch the waterfall while the snow is falling. Kind of cozy
Steve "Centennial Man"
02-13-2017, 06:32 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
subscribing
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
02-13-2017, 06:41 AM
1984 27' Airstream 270
Scotia
, New York
If you have no road, how will you get supplies and other heavy/bulky gear out there?
02-13-2017, 10:46 AM
Delta
It's well out of reach of a crane . I am a crane driver so know the field well. It's up and over some 100 ft trees.
02-13-2017, 10:50 AM
Delta
The helicopter company is all over it . Quite easy in there minds. With their smaller helicopter they can lift 8000 lbs.
12 minutes fly time each way from the air port so leaves 36 minutes to do the lift to keep it with in a hour. 5k Canadian $
02-13-2017, 10:52 AM
Delta
There is a deer path which I can expand into a quad Road very easy.
02-13-2017, 10:55 AM
Delta
Thanks great lead
02-13-2017, 10:59 AM
Delta
Being a crane driver I have lifted all sorts of things onto ships. So I am sure it's been done. Thanks for the info.
02-13-2017, 01:03 PM
Ebro
, Fla Panhandle
Or if the location we are talking about is in the Ca delta, you may be able to float it into place over the next week.
Let's hope not, but.
Cheers Richard
02-13-2017, 01:26 PM
1999 25' Safari
Houston
Not bad. I was going to guess 10k, depending on where the helicopter was. Never thought of a helicopter as a TV. That would be a grand entrance into the campground
02-13-2017, 02:30 PM
2007 30' Classic S/O
Somewhere
, South Carolina
I thought someone here had a thread about lifting one from front yard over home to new backyard locked in spot with a crane.
Maybe try searching.
02-14-2017, 05:20 PM
Catfish Corners
, Georgia
Hunting lodge in the Canadian wilderness? Can't wait to see how this plays out. Should be a nice project.
