Old 04-03-2007, 08:51 AM   #1
Auretrvr's Avatar
Iowa City , Iowa
Hail x 2!!
This morning we awoke to the nauseating sound of hail falling. It was slightly larger than the hail that hit last weekend, but I don't think did any damage, I stood at the window both times telling Ernestine to stand up to it. She had a run in with some larger stuff when with the PO, but she doesn't need any more badges of courage. A girl has her pride, you know!
We are hoping to put up an RV garage structure that we want to cover with shade cloth to protect from UV and hail. We have had this material as a deck cover for over 20 years and it still looks new. What we can't find is source for the frame. We want a 14x14x32 round top (rather than peak) frame. The ones I have found are over 2k...we think too expensive. Any ideas?
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 04-03-2007, 08:55 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
You know, before I got the Safari, I had the Bambi and it was parked outside. Every storm I would cringe. We park the Suburban and one other car in the garage, but 2 other cars stay out. One storm came by, hail, no damage to either car. Another storm came around a few weeks later, and dented both cars pretty bad.
Why don't I feel to bad? Well, it's easier to get hail damage fixed on a car than it is on an Airstream!
I know what you're talkin' about having been through it.
Old 04-03-2007, 08:59 AM   #3
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
shelter
try-tech.com is where I got my fittings. I used 1 3/8" galv chain link fence posts. Mine is 18X30. got about $650 invested, can be disassembled and taken with. There's lotsa places on line. Good luck DG
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 04-03-2007, 10:06 AM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I've been drooling over the tension-fabric buildings linked below for a few years now, they have near everything, probably high-tension price tags too..
Agricultural Supplies, Fencing, Equine Buildings, Grain, Manure Livestock & Kennel Buildings from FarmTek
Old 04-03-2007, 10:45 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Hail WARNING
North Texas (Red River area) and ARK-LA-Tex area forcast baseball sized hail this evening. (April 3) More than a fabric cover will be needed. Mine is in the barn already.
Old 04-03-2007, 11:38 AM   #6
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
I'm cringing as storm after storm is passing over us today, only pea-sized hail so far. A forecast of baseball sized hail? Yikes! Good luck to all of us while this big cold front does its business with us. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 04-03-2007, 06:22 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
try here. they are reasonably priced.
Powell & Powell Supply Company :: Home
john
you call them ferrets, i call them weasels.
Old 04-03-2007, 06:50 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I just checked the radar....an 80% chance of hail and I am in NC, by the radar it MIGHT just squeak by to the south of me...Oh well advantage of beat up vintage units...I guess BTW both are sitting within less than 10' of the back steps
Edit: It is up to 90% and 1.75" hail
Aaron
WBCCI #XXXX AIR #2495
Old 04-03-2007, 07:34 PM   #9
1995 30' Limited
Ashland , Missouri
Good luck, Aaron. I hope it's passed you by safely. ~G
maxandgeorgia
WDCU
Old 04-03-2007, 07:46 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
It went right over the top blew my poor guineas out of the tree, had to turn a spot light on so they would go back up in it. We have a barn, but they won't roost in it anymore...
Hail was about 1/2-3/4" or so.
Aaron
Old 04-03-2007, 08:07 PM   #11
WayWard Wind's Avatar
2004 25' Safari
Here's what we use. No it won't stop large hail, but does give a false sense of hope.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 04-03-2007, 08:48 PM   #12
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
Have a pportable fabric vehicle storage (john hd). Worked well through moderate weather but came down during a heavy blow. Had disk anchors, not enough. I rebuilt using fence post at every pole and taped all pole seams and it is pretty secure now. Of course I say that as the storms dance around us tonight....Not big enough for the Air Stream, but protects pne of my wood boat projects. Would not want that getting wet
Catmando
"Thereís not much in life we canít over-analyzeĒ
rmpray is offline   Reply With Quote
Old 04-05-2007, 07:16 AM   #13
Auretrvr's Avatar
Iowa City , Iowa
A shelter idea....
We have looked at several garage kits, but keep searching because a) they seem to be running around $1500 to $1800 and b) we want to use shadecloth instead of the tarp material that comes with the kits.
We want to come up with a 14w x 12h x 32L. One recommended site had do-it-yourself fittings that work with 1" conduit pipe. (We would run 4 -8ft. sections to get the 32 feet. We are also considering a design that would allow for pvc pipe to hoop the top. I have found a site for bulk shadecloth, but am welcoming any thoughts you folks might have.
Here is a link to the site: Custom Canopy Kits
picture S12 is an example of one they designed.
AIR 15765
Hail damage $$$ settlement recap - 2004 Classic gklott 2001 - 2005 Classic 30 10-04-2007 09:52 AM
Hail and other Near Misses Foiled Again Off Topic Forum 2 07-03-2006 09:40 AM
Hail Damage stratosboat1 Member Introductions 31 05-23-2006 07:42 AM
Hail, Hail and we're still here GreggH Off Topic Forum 10 04-09-2006 06:48 PM
Hail Damage jcanavera Our Community 4 03-30-2002 09:24 AM
