Old 08-22-2014, 02:15 PM   #1
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Gear Ratio... High or Low?
I watched a cool video regarding manual transmissions posted on another thread that you can find at the link below:
http://www.airforums.com/forums/f463...ml#post1499865
For reference, here's the video link:
On a related note I'm curious about the opinions of those who may want to comment on gear ratio. For example, in the video the gear ratios were 1st: 90:30 (3:1), 2nd 90:60 (1.5:1) and 3rd 90:90 (1:1). Similarly, differentials might have ratios in the range of 4.10:1 to 2.73:1.
In both cases I refer to "low" gear as the ratio with the highest numerical value. And, "high" gear as the ratio with the lowest numerical value. I've used this terminology all my life. Perhaps because 1st gear is the lowest (slowest, other than reverse) and high gear is the fastest. So a vehicle with a "low rearend" (differential gear) might be a 4.10:1 and a vehicle with a "high rearend" (differential gear) might be a 2.73:1.
I guess my OCD is acting up today. Otherwise, who else would be concerned about such matters?
Please forgive me if this has already been discussed. I have to admit I didn't take time to search before posting.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is online now   Reply With Quote
Old 08-22-2014, 03:47 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
This is a more up to date version.
2004 Excursion 4x4
Old 08-22-2014, 05:28 PM   #3
Wayward's Avatar
Cary , North Carolina
Yeah. Not OCD, We all trip over that too
I think you are correct, a "low" gear is from the driver perspective because it is labeled with a low number on the shifter - but the numerical ratio is high e.g 4:1.
It has carried over to rear axle ratios as well even though drivers do not even think about the differential gear ratio. I will say that my truck needs a lower rear end gear, even though I know I need a high gear ratio.
FUnny who most peopel can identify with the concept of a "low gear" even thigh they have never been exposed to the concept of gear ratio.
Oh well....we are stuck with it. Context is everything! When needed I just say "higher ratio gear"
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 08-22-2014, 06:35 PM   #4
SteveH's Avatar
Common Sense , Texas
One way to avoid problem is to not say gear ratio, but axle ratio and then the numbers must be used, which everyone understands.
Regards,
Steve
Gear Ratio ??? slow-canoe Argosy Motorhomes 2 07-24-2007 10:09 AM
Gear ratio (rear end) for towing bhayden Tow Vehicles 19 06-20-2006 08:23 AM
Gear Ratio ? slow-canoe Mechanics Corner - Engines, Transmission & More... 9 04-10-2006 08:29 PM
Gear ratio for my GM TV Double D Tow Vehicles 20 02-16-2006 07:41 PM
tow vehicle gear ratio redlion7 On The Road... 16 03-07-2004 06:25 PM
