Old 02-22-2010, 07:42 AM   #1
Cranbury , New Jersey
Question Furnace did not turn on
My furnace did not turn on starting last week. It used to work fine. When I turn on the thermostat, the fan works, but the furnace did not turn on, so it just circulate the air. I replaced the filter, but the furnace still did not turn on. The model of our heater is Goodman, only 2.5 years old. Anybody has any suggetion? Where should we start to look? I'm a beginner. Any suggestions are appreciated.
Kumon22 is offline   Reply With Quote
Old 02-22-2010, 10:55 AM   #2
Kevin245's Avatar
What is your furnace installed on?
Kevin
Eleanor Roosevelt
Old 02-22-2010, 10:58 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I had same thing
The problem was that my converter had been turned off....the batteries drained to a low point where the fans all worked but the furnace would not ignite. Turning on the converter and subsequent battery charge fixed it. Hope this is you problem too.
Old 02-22-2010, 11:08 AM   #4
My furnace was installed in the attic, so it's on the wood floor.
Old 02-22-2010, 11:10 AM   #5
Melody Ranch, thanks for the sharing. What is converter and where is it located?
Old 02-22-2010, 11:16 AM   #6
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Well, I assume a furnace is a furnace.
Wood floor attic? Well, I guess your not in an Airstream....regardless, check it out. A converter is normally somewhere near where the electricity feeds into the "unit."
Old 02-22-2010, 11:37 AM   #7
Thanks! I'll check out the converter then.
Old 02-22-2010, 03:57 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
It does not appear that Goodman makes furnaces for Airstream Travel Trailers. Rather they make furnaces for residential use. If that is your case it will be difficult for us to assist on this forum as residential units will be natural gas or electric. Airstream furnaces are powered by propane. While similar there are differences. A residential unit will not have a converter as the power will come from 110v AC current from the home and does not need to be converted.
Air Conditioners, (A/C), Packaged Heat Pumps and Central Air Conditioning (AC) Units for Home Healing and Cooling Systems. Residential and Commercial Heating and Cooling Equipment by Goodman Manufacturing available in 14 SEER and 13 SEER ratings for
>>>>>>>>>>>>>Action
Fridge won't turn on flmgrip Refrigerators 4 02-13-2010 04:20 PM
won't turn off! AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-22-2009 09:52 AM
When to turn on heat??? tmarquis Winterizing, Storage, Carports & Covers 5 03-24-2009 09:40 PM
The PO was going to turn it into a shed! kenthelen Member Introductions 9 07-18-2008 09:57 PM
