Old 04-05-2010, 08:36 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Flag Poles
I have been attempting to contact the person selling flag poles and flag pole holders. I have called the phone number but no one answers and have sent a message to the e-mail address. No contact. Does anyone have any updated information where I could purchase some poles.
gaylejoe is offline   Reply With Quote
Old 04-05-2010, 08:49 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I bought a flag holder from poleease some time back and I send you a PM with the last good email and phone I have for the company.
I did not buy poles from them, I made them from 12' painters poles which I bought at Loews. I added a little hardware to them to hold the flags and they work very well. I did have to make the holes in the holder slightly larger for the poles to fit.
Richard
Old 04-05-2010, 10:10 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I also used painter poles from Lowes...Home Depot has them too. I made my holder from hardware available from any hardware store for WAY less than the fabricated ones. Here are photos of my set up. I carry the poles in 4" PVC anchored to the coach bottom.
Neil
Name:	July, 2009 through October, 2009 518.jpg
ID:	99572   Click image for larger version
Name:	July, 2009 through October, 2009 517.jpg
Name:	July, 2009 through October, 2009 516.jpg
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-06-2010, 08:00 PM   #4
gaylejoe's Avatar
St. Hedwig , Texas
Thanks guys for the great information. Going to Lowes tomorrow.
Old 04-06-2010, 08:08 PM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
I used eye bolts (2) and wing nuts on each pole and then clip the flags on to them. I remove the lower eye bolt when stored so they collapse smaller.
Richard
Old 04-07-2010, 06:31 AM   #6
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Another Flag Pole Option
I like the do it yourself pole plans already stated. Here is a link to collapsible pole available with Internet access and a credit card. Scroll down to Collapsible Flagpoles To Go. Warning, they are not cheap, but they are really nice, and very easy to store.
Name:	IMGP2315 small flag.jpg
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 04-07-2010, 09:29 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
The paint roller extensions are very economical and easy to find at Lowe's. I left the handles on mine and secured the top of the flags with a nylon zip tie on the handle and another down low at the other flag grommet.
The poles have withstood strong winds and the ties have not slipped. I got the holder from Rob (RobandZoe).
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-21-2010, 12:25 PM   #8
2000 34' Limited S/O
Jamestown , North Carolina
Flag Pole Light
Thanks. Been frustrated that I couldn't get in touch with Pole Ease. They must be out of business. Just ordered from Flag Brackets, Flag Poles, Flagpoles, Flag Hardware & Accessories.
I'd like a light to shine from the bottom to highlight the flag at night. I've seen some pretty tacky concoctions, however I'd like something neater. I did see on another Airstream a light that had been mounted on a magnate that was attached to the Hensley that had a small positive and negative connection which I think could be used in the Airstream light connection when it unhooked. I'd appreciate any ideas like the flag pole suggestion from ts8501.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 05-21-2010, 01:37 PM   #9
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Look here to get an idea. They are too pricey but will give you a place to start from.
http://www.ycasolarlightstore.com/So...FUFM5QodRhgNKw
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 05-21-2010, 02:04 PM   #10
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
what you could do for a light is get a 12v landscape light fixture..if you can find one, get one that mounts w/ a threaded pipe...that pipe matches the threads of a standard outdoor light box.
you could use one that mounts w/ a spike, meant to stick in the ground. that'll work at some campsites...if you're camped on cement/pavement, not so much. But you could probably rig a base that would just sit on the ground.
Then get a female trailer (7-way) plug, clip the connectors of the landscape light, and wire it into the trailer plug. (put a fuse inline!!). Then you can just plug it in to the trailer's umbilical when you want to use it. adding a switch is optional.
I mounted an outdoor electrical box, and put a switch on the side of the box. That works with my arrangement. What I found when researching this, myself, is that nearly every trailer-tongue is unique, in terms of wire accessibility, jack presence/location, tanks, flagholder, etc...what you see on someone else's trailer may not work on yours, so you have to be prepared to be creative.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-21-2010, 02:56 PM   #11
Gator113's Avatar
2007 25' Classic
Port Angeles , Washington
This may be late, but go contact robandzoe at this link http://www.airforums.com/forums/f4/f...tml#post849463
PoleEase no longer makes them but Rob does. They look rugged and I just ordered one. Mine should be here next week. He has two sizes-- 3 or 5 pole holes that I know of. They look great.
Gator113 is offline   Reply With Quote
Old 05-21-2010, 06:58 PM   #12
Thanks. Bought my flag holdder already from Rob, then my flag pole today from the Flags from American Flags per this thread. Now I'm looking for a light to light it up at now. Will check out the solar suggested in an earlier post.
WBCCI #4358
Old 05-21-2010, 06:59 PM   #13
Solar Flag Pole Lights
Great thanks! Pricey but worth it I think.
WBCCI #4358
Old 05-31-2010, 02:25 PM   #14
I ordered the flagpole over a week ago. I have received an email that they are on back order. Did you have any problem receiving yours?
WBCCI #4358
Flag poles and holder for tongue jack NOAZRK2690 Off Topic Forum 32 11-13-2009 07:36 PM
Awning poles jillwill Awnings 10 08-29-2009 08:37 PM
Flag holder barksdm General Motorhome Topics 7 07-14-2008 12:01 PM
Awnings? arms or poles? fancy pants Community Polls 7 04-05-2007 08:18 PM
Awning w/poles Jabba Awnings 15 02-01-2003 12:13 PM
