Old 04-19-2010, 01:09 PM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
EZ Pass Overcharging
This is to let you know that several EZ Pass transactions will likely be overcharged when using EZ Pass.
The Delaware Memorial Bridge in south Jersey will charge any car and trailer combination as a truck and will be $2.00 extra for a 2 axle trailer and $12.50 extra for a 3 axle trailer.
The Route 78 bridge between NJ and Pa will charge $11.65 for a 3 axle trailer when the charge should be $1.50
The Maine Turnpike has charged as much as $22.00 extra for a tri axle trailer.
As a good rule you should not use EZ Pass while towing unless you know the tolls are correct or unless you like to ask for credit after each trip.
The Bay Bridge at Annapolis and the Peace Bridge charge correctly.
If you know of others that overcharge please add your comments.
2004 Excursion 4x4
Old 04-21-2010, 09:45 AM   #2
Catman6's Avatar
1986 Argosy
Denver , Pennsylvania
I wonder if I'll still get the discounts when hooked up since I'm on the comuter plan ...
Catman6 is offline   Reply With Quote
Old 04-21-2010, 11:13 AM   #3
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
I use EZ Pass all the time. But I have never had a trailer behind me. Do you contact them when you plan to have a trailer tow, i.e. updating your vehicle information?
Rae
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 04-21-2010, 11:48 AM   #4
Catman6's Avatar
1986 Argosy
Rae
No, you don't need to conntact them. You can't use all of the high speed lanes (some say no trailers so read your signs), but it registers and counts axles as you pass. I've never looked at my bill to see what I was charged though.
Old 04-21-2010, 12:05 PM   #5
HowieE's Avatar
Images: 12
Rae
To use EZ Pass while towing you have to register the trailer with them. The overcharging seams to only be a problem with the named agencies while towing a trailer. Their systems are set up to count axles and even though the account has a RV trailer registered it will charge you as a commercial unit with that number of axles.
A simple mistake designed to overcharge those that do not watch their accounts. I have talked with the Delaware River Memorial Bridge people 3 years ago and they acknowledge they know of the problem but have no intentions to correct it as it is a major money maker so you have to pay cash or ask for the credit each time you tow.
2004 Excursion 4x4
Old 04-21-2010, 12:09 PM   #6
HowieE's Avatar
Images: 12
Can't answer that question. I would advise you to tow and pay cash to establish the correct toll for each agency and then use EX Pass and check the bill. The Pa turnpike dies charge correctly as far as tolls but frequently has you entering or leaving from the wrong exchange. To get a credit from Pa turnpike you have to contact them directly as apposed to contacting you EZ Pass agent for all other credits.
2004 Excursion 4x4
Keep Right Except To Pass?? Mackhopp Community Polls 42 04-13-2010 02:20 PM
GoldenAge Pass aka America The Beautiful-The National Parks & Federal Rec Lands Pass Driver1 Boondocking 16 07-22-2009 10:00 AM
Alternator Overcharging? kennytheecat Batteries, Univolts, Converters & Inverters 7 05-15-2009 04:44 PM
E-ZPass Question dudebb On The Road... 11 09-18-2007 03:40 PM
Batteries Overcharging genearnold Batteries, Univolts, Converters & Inverters 1 09-05-2006 09:26 AM
