Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 04-08-2008, 12:01 PM   #1
Bambi_Bandit
Bambi_Bandit's Avatar
Profile:  2008 27' International CCD FB
Enkay flaps at Costco.com
Costco is carrying the Enkay flaps (the new design) for a great price of $179.00. Price includes shipping and handling.
Costco - ROCK TAMERS™ Removable and Adjustable Mudflap System=
As with any non-elctronic item purchased at Costco, you can return it at the local warehouse for a refund.
I have them on my Hensley shank. Needed to do a little trimming on the collar of the Enkay to get it to sit flush with my truck bumper. (I didn't watn the longer shank from Hensley as the lifetime exchange policy does not apply to the extended shanks)
Kevin & Prim Li
Bandit the Siberian Husky & "G" the Min-Pin
2008 27FB Intl CCD Customized by Airstream & David Tidmore @ Roger Williams Airstream
2005 Ford Excursion Diesel 4x4
WBCCI # 11809
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 04-08-2008, 02:14 PM   #2
1953 Flying
1953 Flying Cloud
1953 Flying's Avatar
Profile:  1953 21' Flying Cloud
Sacramento , California
Images: 8
Thats a great price. Thanks for the information.
_______
Robert
Life is like a roller coaster, a whole lot of up's and down's..
1953 Flying is offline   Reply With Quote
Old 04-08-2008, 03:43 PM   #3
silverback
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
Kevin,
Can you describe the trimming in a little more detail? I also have a Hensley.
Ken
4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
silverback is offline   Reply With Quote
Old 04-08-2008, 09:22 PM   #4
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Enkay hub modification
Check out this thread of the modification I had done on my Enkay hub by a local machine shop. http://www.airforums.com/forums/f238...tch-17562.html
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 04-09-2008, 09:02 AM   #5
Bambi_Bandit
Ken,
What Craig posted above is correct. I only had to grind a small corner of my Enkay collar to clear the weld of the hensley stinger... The only other difference was the Enkay I have are the newer revsion that is a lighter weight chrome colored metal as compared to the previous heavier brass colored metal material they used before....
Kevin & Prim Li
WBCCI # 11809
AIR # 6155
Old 04-09-2008, 09:33 AM   #6
aluminauts
aluminauts's Avatar
Profile:  2003 34' Classic
vancouver , Washington
only some filing
As noted in post 3 and 4 of Craig’s reference, my adjustment was only some filing along the rear edge of the collar. It seems the clearance for the sides of the dropbar are particular to every shipment.
Aluminauts
2003 34' Airstream Classic
2007 Chevy Silverado 2500HD
Allison Duramax 4X4
Hensley Arrow hitch
Kodiak / Actibrake Disc Brakes
Tekonsha Prodigy brake controller
Doran Pressure Pro
WBCCI #2984 Air # 4173
aluminauts is offline   Reply With Quote
Old 04-09-2008, 11:53 AM   #7
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
This is a pretty good price on these. These fit snug with my Reese dual cam system. I only had to trim some of the lower mudflap off so that it wouldn't drag on the ground, even set to the highest setting.
I would also suggest to anyone getting these that they are NOT a subsititute for regular mudflaps. Some things can get by the Enkay flaps. I found that with a good set of mudflaps and the Enkay, that even on washboard type gravel roads, I've not had a ding or scratch caused by projectiles coming off my tow vehicle.
Old 04-09-2008, 01:02 PM   #8
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Just curious which type of mudflap are you suggesting here?
Also, is anyone aware if the new style mounting bracket can be trimmed to work with the Hensley? I only see references to the older style.
Thanks!
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 04-09-2008, 01:30 PM   #9
Bambi_Bandit
Thanks!
I have the new style chrome colored collar / bracket, and I did trim it to work with the hensley "stinger" shank.
Kevin & Prim Li
WBCCI # 11809
AIR # 6155
Old 04-09-2008, 01:32 PM   #10
Bambi_Bandit
Agreed - there is the gap between both flaps that the occasional rock will get thru. Some have put flaps under their reciever area in the center for this, but I'm OK with the coverage I have with the mudflaps on the rear wheels and the Enkays combo.
Kevin & Prim Li
WBCCI # 11809
AIR # 6155
Old 04-09-2008, 01:51 PM   #11
Silvertwinkie
Aluminut
Thanks!
It really depends on what vehicle you have. Each vehicle tends to have different mounting methods to mount the basic mudflaps to the vehicle.
In my case, I bought the Chevy truck flaps and extended them with attached flaps to lower the blocking ability. My pops had just the standard flaps (no extensions or Enkay). We all met up boondocking in the woods after towing 30 miles on sandy, gravel, dirt type roads. His SOB was covered in the front with sand, dirt, water mist from the tires being in the crater puddles, etc. My Safari only had dirty water mist, and not a whole lot of it.
Between both, I don't get anything... now if my Enkays could only stop small thinks from oncoming trucks and of course bird droppings and bug splats!
What do you guys think of this solar kit available at Costco? wacnstac Generators & Solar Power 13 05-09-2007 10:07 PM
Hensley and Enkay Rock Tamers Roadtoaster Hitches 5 03-06-2007 09:07 PM
Enkay Rock Tamers: Trim Length Tin Diesel Towing, Tow Vehicles & Hitches 6 05-20-2006 03:45 PM
Enkay Mud Flaps and Hensley Hitch Sonia Towing, Tow Vehicles & Hitches 36 09-06-2005 04:59 PM
Rock Tamer by Enkay davidz71 Towing, Tow Vehicles & Hitches 8 05-04-2004 10:40 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
