Old 03-23-2012, 05:21 PM   #1
2007 25' Safari FB SE
Bemus Point , New York
drying rack for 2007 Safari 25'
Does anyone have a suggestion for a bumper mounted clothes drying rack suitable for a 25' safari?
jetjocky is offline   Reply With Quote
Old 03-23-2012, 06:38 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I made one using 3/4" square aluminum tubing. It has three lines for hanging cloths. Takes less than 5 minutes to install or remove and it stores in the rear bumper compartment. One medium size wash load fits tightly.
I will take pictures in the morning and post it. (if I forget PM me)
Alan
Old 03-24-2012, 11:55 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Clothes line drying rack
I made this bumper mounted rack that stores inside the bumper storage along with all of the sewer connection items. It takes less than 5 minutes to mount or dismount and store it.
The mounting sleeves are attached to the frame using existing 1/2" holes. I used single 7/16" clevis pin with a few washers to make the length correct. There is a small angle bracket mounted on the back side of each sleeve beneath the frame that acts as a stop so that the rear bumper does not get damaged when the sleeve pivots on this single pin. I also use a bungee to dampen the sleeves' movement in gusting wind.
The top member is cut to a length so that it just barely fits into the bumper compartment. The top member has a corner bracket attached inside at each end. The clothes lines are mounted to 3 hook bolts on each side member. The clothes lines are looped at each end so that their length is just shorter than the actual opening. (I lifted it so you could see how its made) The top member normally sets inside of the side members in compression, kept in place by gravity and tension of the clothes lines. The side members are cut just long enough so the top line is as high as DW can reach.
Hope this helps!
Name:	clothes line 001.jpg
ID:	154220   Click image for larger version
Name:	clothes line 002.jpg
Name:	clothes line 006.jpg
Alan
Looking for work campers in central TX scorpiontimo Working on the Road 3 06-12-2015 12:16 PM
LED lights for '68 AS thunderbird General Repair Forum 18 04-09-2012 11:52 AM
Vulkem 116 and Acryl-R, which do I use for what? Sandi & Bob Leaks - Weatherstrips, Gaskets, Caulks & Sealants 20 03-24-2012 09:00 AM
1965 Airstream Safari 22 Restored eBay Watch Airstreams on eBay 0 03-23-2012 01:50 PM
NY State said no to a vintage plate, Time for a letter campaign. HHaase Airstream Lifestyle 14 03-23-2012 10:30 AM
