Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 05-12-2007, 09:21 PM   #1
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Does Your Crack Need Cured...?
If so - thought you might want to bid on this item.....
eBay Motors: Tolley's Creeping Crack Cure for Airstream (item 180116785949 end time May-19-07 19:10:30 PDT)
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 05-12-2007, 09:38 PM   #2
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I looked at the Ebay listing. This is very interestin. Does anyone know if this stuff works?
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 05-12-2007, 09:41 PM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
You can read more about it here; Capt. (Captain) Tolley's Creeping Crack Cure Hairline Crack Sealer
Richard
Charter Member Four Corners Unit
Old 05-12-2007, 09:43 PM   #4
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
I'll stay with my Acryl-R, Thanks! The eBay ad reaks of snake oil .
But you never really know what it is until you try it. 8 ounces will do a trailer....REALLY?
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-12-2007, 11:10 PM   #5
66Overlander
66Overlander's Avatar
Profile:  1994 28' Excella
Oakland County , Michigan
Images: 11
I didn't look at the eBay auction, so I don't know what claims the seller made, but a couple of years ago I bought Captain Tolley's Creaping Crack Cure at West Marine and used it on a water leak above one of the front wrap windows on my trailer after reading about it in a thread on AirstreamForums (or was it on the Vntage Airstream List?). It comes out as a low viscosity milky white liquid, much lower viscosity than Acryl-R or Par Bond. When I applied it, it kept penetrating in as it crept into the crack. And then I'd add more until it stopped "soaking in". It didn't take much to seal that seam above the window, so a bottle might do a whole trailer. After it dried I went over that crack with Par Bond or Vulkem just to be safe. In the end, I am not sure what stopped the leak, but it was stopped none the less. Perhaps not a ringing endorsement, but in combination with other sealants it did the trick in my case, and at the worst it didn't hurt.
Joe
WBCCI/VAC #5533
'94 28' Excella / '05 Hummer H2
(and casually seeking a vintage AS)
66Overlander is offline   Reply With Quote
Old 05-13-2007, 05:29 AM   #6
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
I thought only the worst when I saw the title of this thread...
I have used it, it may work with repeated applications like the directions say, but after 2 days of applying, waiting for it to dry, and reapplying, I finally went and got a tube of Ruscoe sealer, it worked just fine, and on the first application.
The crack cure does have to potential to seal something you can't easily get at, but I think it is more like the cans of K&W Block Sealer you get when your car blows a head gasket. I never had one seal anything, except the cores in the radiator. Better to fix it right the first time, than keep messing with it for days, weeks, ...
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 05-13-2007, 09:49 AM   #7
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
From the description, it might make a good sealer for rivetheads.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-13-2007, 10:17 AM   #8
BigAl
Profile:  1994 30' Excella
Mississauga , Ontario
On my trailer the fixed window in a stacked set of windows leaked. The leak was between the glass and the frame. Through the sealant that is installed by the factory. Looks like a rock hard putty.
The Tolley crack sealer is like a watered down white glue.(Like woodworkers glue). Apply to the crack. It seeps in and dries crystal clear. Apply repetitive coats after the previous one has dried until it won't seep into the crack anymore and you are done.
Worked perfectly for me. I suspect it only works well on hairline cracks.
Al
Old 05-13-2007, 10:32 AM   #9
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hopefully this stuff isn't 'all or nothing' like silicone as far as adhering to aluminum. How would we know until a lot more observation is available? Safer to stick to the Acryl-R IMO.
I assume it is resilient and not hard when set?
Screen Door Crack azflycaster Doors & Locks 14 04-13-2007 09:04 PM
frame crack jimnsue Repairing/Replacing Floor &/or Frame 7 10-09-2006 10:25 AM
Frame crack Creampuff 1966 - 1968 Safari 4 11-03-2004 01:53 PM
Front dome crack davidz71 General Interior Topics 30 04-29-2003 10:18 AM
Hairline Crack in Aluminum. 68 Suburban Ribs, Skins & Rivets 2 03-05-2003 09:11 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
