Old 02-26-2011, 06:32 PM   #1
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Couple of nagging questions..
1) Winterizing. If you drain all of the water from the system, why would you fill it up with anti-freeze? What then are you preventing from freezing if there is no water?
2) Vent stacks. No tops on them. Water falls right in. Inside the vent stack there is a rubber seal thing that the pipe fits up into. Where does the water go that falls into the vent stack?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 02-26-2011, 06:55 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
1) The water pump if nothing else. Some people just blow all the water out with compressed air and do not add antifreeze. I did that one winter. Replaced the water pump the next spring as the seals dried out. So, I fill with antifreeze faithfully now.
2) Water falling into the vent stacks will end up in the gray and black water tanks. Not much rain water really gets in that way.
The rubber seal around the vent pipe keeps water out of the wall. According to several people on the forums, the rubber needs to be replaced every few years.
Old 02-26-2011, 07:52 PM   #3
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
I also understand that even if you blow out the lines, small amounts of water can remain in the faucet valves and possibly cause problems. I blow it out and then pump in antifreeze. I know, it's likely not necessary to blow out the lines if you are using antifreeze, oh well, I'm a guy and I like to do things like that! As to antifreeze to me, it's just cheap insurance.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 02-26-2011, 08:23 PM   #4
The water that surrounds the sewer vent pipe, within the vent pipe cover, runs out thru the built in holes, in the bottom side of the cover.
Old 02-26-2011, 08:26 PM   #5
Draining the water, is being "hopeful" that you don't get a freeze up.
Adding antifreeze, provides a "guarantee" that you won't get a freeze up.
Cheapest insurance you could ever invest in.
Old 02-26-2011, 09:16 PM   #6
DanielB's Avatar
Ah! Didn't notice those (if in fact they are really there.. as you say)
- Andrew Carnegie
Old 02-26-2011, 10:36 PM   #7
1965 22' Safari
Gerlach , Nevada
Send a message via Yahoo to Tazameir Send a message via Skype™ to Tazameir
Like others have said here. You can't be too safe.. I say spend the 10-15 bucks on the pink stuff, and make sure to run it through all your lines and drains. Well worth the cheap investment. In the spring you can reclaim some of it, and re-use it if you wan to save a buck. We winterize houses here all the time, and have to use more for those lines as they are bigger, etc. But still... If you miss blowing a line out, or water settles somewhere and freezes..... Not fun having to fix split lines. I've done it, it's no fun.
C.
Chris Petrell aka Taz
1965 Safari - 1987 F250 4x4 | Member Black Rock Desert Rats 4x4 club | AIR #53724 | TAC NV-3
1997-Current Burningman Participant / 1999-Current Staff member.
--- Life is an endless stream of choices ---
Tazameir is offline   Reply With Quote
Old 02-26-2011, 10:41 PM   #8
Trex's Avatar
1981 20' International
Shasta Lake City , California
Just remimber to check that serwer pipe vent 356 days a year... good way to get a work out;0
"Sometimes you eat the bear, and sometimes, well, he eats you." -the Stranger-
Come and see me at: http://www.airforums.com/forums/f185...-71804-60.html
Trex "Airstream Nomad"
Trex is offline   Reply With Quote
Old 02-26-2011, 10:46 PM   #9
x
XXXX , XXXX
Rex which of the nine days of the year do you suggest not checking the vents?
wasagachris is offline   Reply With Quote
Old 02-26-2011, 11:52 PM   #10
Trex's Avatar
What I was trying to get across. That the rubber casket will leak. They dry up and the pipe will slip down and water will cause damage to your plywood floor. So, get up there and check you sewer pipes! Hope your project is going well Mr. Was....
Old 02-27-2011, 05:46 AM   #11
x
XXXX , XXXX
Rex I can't help but laugh. First a typo shortened the year from 365 days to 356. Now you're talking about the rubber casket that will leak. Who gets buried in a rubber casket anyways. When they drop you in the hole you'd bounce right back out.
Old 02-27-2011, 05:51 AM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
When I read the title I thought the questions would be:
1) When are you going to take the garbage out?
2) Have you taken the garbage out yet?
Wayne&Sam is online now   Reply With Quote
Old 02-27-2011, 06:09 AM   #13
x
XXXX , XXXX
LOL. or
1) When are you going to get all the trailer parts out of the house?
2) When are you going to get rid of that junk piece of aluminium off the driveway?
Old 02-27-2011, 10:10 AM   #14
Minno's Avatar
1972 31' Sovereign
National Holidays are probably good days to skip the checking.
1975 Tradewind project - questions! lots of them! keithmac 1970-79 Tradewind 4 03-05-2011 10:10 AM
'62 Safari electrical update questions Peggy Wilson Electrical - Systems, Generators, Batteries & Solar 3 02-12-2011 07:23 PM
Questions for shell-off project wworx Repairing/Replacing Floor &/or Frame 10 02-10-2011 06:59 AM
A couple Overlaner questions. DougZ 1972 Overlander 2 01-17-2011 05:04 AM
