Old 11-13-2013, 07:55 AM   #29
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Here's a link to a good summary of the Federal requirements for trailer lighting and reflectors:
http://www.expediter.com/pdf%20folder/J%20folder/J28-30.pdf
I ran across this link while searching or requirements for trucks and vans, since I plan to add conspicuity tape to my Interstate. I can't use it, but maybe you guys can.
Airstream trailers already come with all legally required markers and lamps. If you add conspicuity lights or reflectors beyond the legal minimums, it's probably a good idea to comply with the placement requirements for larger trailers, and not just put them anywhere you feel like putting them.
Mexray's all-around blue lighting would be illegal in Louisiana, according to Louisiana Revised Statute (LRS) 32:309. This link should give you a good starting place for determining the legality of nonstandard lighting by state…
Unlawful Vehicle Modifications: State Laws - FindLaw
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-13-2013, 08:09 AM   #30
Skater's Avatar
1995 30' Excella
Bowie , Maryland
The stripe on our trailer (and the one on the B190 for that matter) both have a reflective white strip in them. It looks like just ordinary white during the daytime, but at night it's pretty bright when you shine a light on it. When we had the B190 parked in front of the house, as we came around the bend at night toward our house, that white strip was the first thing we'd see. Too bad Airstream got away from that...it really is a nice touch.
For example check out this auction and see the white and blue reflective tapes. A strip of that somewhere along the camper, bottom edge perhaps, should work well and be fairly inconspicuous. I found all kinds of options using the search term "reflective pinstripe tape".
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-13-2013, 08:22 AM   #31
The Sprinter vans used by Cox Communications for their cable service techs have a white reflective band about the same place that Airstream Interstates have their chrome band (there are three of those service technicians living on my block, so I see their trucks all the time). I'm thinking of putting a similar white reflective band on my Interstate, just below the chrome band (and a matching one on my toad while I'm at it). But for the back of the Interstate, I'm going to stick with DOT-approved red-and-white reflector tape on the rear bumper and mudflap supports (I have a removable hitch-mounted mudflap for when I tow my Honda) and white reflector tape around the upper corners of the rear door frames, since those are the approved colors and locations for reflector tape on trucks.
WBCCI #1105
TAC LA-4
Rear window reflective film jaiman Windows & Screens 4 04-06-2018 02:10 PM
Reflectix Reflective Insulation toastie Upholstery, Blinds, Walls & Interior Finishes 33 01-18-2014 05:11 PM
3m mounting tape billiards Generators & Solar Power 4 05-28-2010 04:02 PM
How do I remove this @#$% tape? 63Silver Exterior Restoration Forum 34 02-12-2009 07:31 PM
Reflective Safety: Conspicuity Tape slowmover Towing, Tow Vehicles & Hitches 8 11-17-2008 07:37 AM
