08-30-2002, 10:00 AM
#29 Vagabond
Profile:
1973 31' Sovereign
Semi, Pro Rock Crawler
, Motorsports Photographer
Can you hear me now!!!!!!!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
08-30-2002, 10:10 AM
#30 4 Rivet Member
Profile:
More than I ever thought I needed to know
You document supports my case indeed!
The Aluminum/Tin Debate
In general, when people say "tin foil" they really mean aluminum foil. But what about tin (Sn)? Does it have the same anti-psychotronic properties as aluminum? Most experts agree that tin does have an effect but opinions are divided as to whether or not it is as good as aluminum. A small, but vocal, contingent even argues that tin is superior, but they are held by most to be the lunatic fringe of Foil Deflector Beanie science. I would advise people wishing to build a Deflector Beanie to stick with aluminum whenever possible since it is a proven technology.
08-30-2002, 08:07 PM
#32 Rivet Master
Profile:
1965 20' Globetrotter
Houston
Be afraid....be VERY afraid....
-BobbyW Posting from AirStream Bizarro World,
were everything is opposite!
-BobbyW AIR# 123 - Guess what? I got a fever! And the only prescription.. is more cowbell! -"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches." -Red Green www.bobbywright.com/gallery
08-31-2002, 09:58 PM
#34 Vagabond
Profile:
1973 31' Sovereign
Man is this FUN!!!!!!!! (LOL)
09-01-2002, 07:44 AM
#35 Rivet Master
Profile:
Houston
OK ...OK I won't do it. You people have convinced me.
From now on I will always....Use Vulkem/ParBond/Sikaflex to seal, never Silicon, Use Nuvite and a Cyclo polisher to polish, Install Fantastic Fans, Pull with a properly equipped 1 ton supercharged diesel 4X4 dually crew-cab rig, instead of my CAN-AM Yugo, Balance my wheel assemblies, Plumb with PEX, Install Pergo flooring, Order and read an owners manual from Helen Davis @ Secretarial Services at: (937) 492-8885, Paint the interior with Zolatone, Install and shave Olympic rivets, Install a rock shield on the front, Walbernize my exterior, POR-15 coat my hitch, Replace my batteries and keep them charged, Install a solar panel(s), Not attach anything to my rear bumper, Quit trying to figure out how to install a Gray-water tank, Update my LPG regulators Use ST Goodyear/Cooper/Continental D rated tires and 2600lb+ trailer wheels, Install new full brake assemblies, instead of repair the old ones, Install OEM Gabrial Shocks, not NAPA automotive, Never put a jack on the Duraflex axle, Only use ZipDee awnings, Clean and inspect my A/C unit annually, I will bring/not bring children to the Rallies, Use a dremel tool for everything, on everything, that won't move, If it will not come loose with the proper tool, I will "heat & beat" it into submission, Winterize the plumbing before the first thaw, Keep my Black Water tank at least 1/3 full, Not use excessive HTML, colors, punctuation and all CAPS when posting to the Forums, Quit adding things to this post, Finish my current restoration, instead of hanging out here all the time, posting silly stuff like this... -BobbyW Posting from AirStream Bizarro World, were everything is opposite!
And still wasting time adding things to this post...
09-01-2002, 08:00 AM
#36 3 Rivet Member
Profile:
DITTO!
www.ISellThousandOaks.com
09-01-2002, 07:22 PM
#37 4 Rivet Member
Profile:
Thank you!
BobbyW,
Thank you for saying so very much about something so important
to us all.
Never before have I seen such powerfull statement of structure, function, and passion.
Never again will a thread about nothing,
become something so wonderfull.
Again,
Thank you.
09-01-2002, 08:01 PM
#39 Vagabond
Profile:
1973 31' Sovereign
WOW, BobbyW you got all that out of airstreamcaravel first post, You relay can read between the lines!!!!!!!!!!!!
09-01-2002, 08:06 PM
#40 4 Rivet Member
Profile:
Its all right there!
I vote for a link on the home page to BobbyW's statement.
It could be labeled "the 10 second Airstream Primer"
or:
"Everything you need to know about Vintage Airstreams"*
*but was to green to know to ask!
1 vote 1 voice 1/2 a brain.
09-01-2002, 08:09 PM
#41 4 Rivet Member
Profile:
Oh by the way!
That's Helen Davis at Secretarial Services: (937) 492-8885
Thread Tools Display Modes Linear Mode
