I don't recommend sideways to travel mounting for long term fork mounting but rather longitudinal mounting.
Maybe you're able to stop faster with the MH than a trailer but I doubt there's a lot of difference between the stop/go force and cornering. Eye hooks and a few bunge cords would take care of it and keep things from going "bump in the night". Come to think of it, wasn't your coach designed for the "cargo" to be laid out flat
The real dog is our next trip is likely up to the Methow in October and they plan to run a cyclocross race on Saturday and mtn bike XC on Sunday. Four bikes in the trailer is starting to get cramped
We would not recommend a front mount hitch for the bikes.. Did that and the bikes imped your vision thru the windshield... we had a very near miss last spring coming home from Fla..our TV is a F250 ...
My front hitch protrudes from the center of the bumper, so with a bike rack, the bikes would be in the line of sight through the windshield. I use a 10" hitch drop so the top of the bikes are even with the truck hood.I also use the Swagman three bike towing bike rack. It has a 2" square tube that mounts over your 2" hitch draw bar - works great.I also purchased a 2 bike rack stand for neatly storing the bikes outside and have used it to stand the bikes up inside the trailer while traveling. This has also worked out very well since the bikes are standing very secure and not lying on the floor.
WBCCI 24291
New England Unit
Metropolitan NY Unit
Peegreen.. Thanks for the info.. when we travel with the 5th wheel.. we have a canoe loader in the front hitch and the bike rack on the back of the 5th wheel.. have already checked with the manufacturer about bike racks on back..
Has anyone added a bike rack to the back of their airstream ? Any suggestions on what type and how it was attached would be appreciated.
I agree, don't put anything on the bumper of the Airstream. I too thought of placing bikes inside the new RV, but then thought, why, sure it'll cost a bit more, but there is no question of zero damage to the inside due to shifting, etc, if you find an alternate solution.
Not sure what your tow vehicle is, but I went this route:
I'll reply to some of the concerns voiced previously;
Never had a problem with cooling while the bikes were on the front hitch.
Don't really care if they get "bugs" on them. We MT bike and they get filthy any way. I clean them when the trip is done.
We have a p-up now, bikes and other stuff in the bed ( I have snaked a cable through the stake pocket so I can lock em up pretty good...) and kayaks on the roof with a Thule rack.
Never really had a problem with line of sight with the bikes up front. I took the seats off and threw them in back. This leaves only a small diameter tube in your line of sight. Didn't really bother me (or effect headlights at night).
For us, the front hitch worked great; easy access, had the rack with me if we wanted to go explore outside the campground, didn't have to lift bikes on to a rather high roof, freed up the roof for kayaks. Never had any ground clearance problem either, although we don't really "four wheel".
Another vote for bikes on the front receiver hitch
Another vote for bikes on the front receiver hitch. See picture.
__________________ Airstream25 KE5CKG on 2 meters Four Corners Airstream Unit AIR #10274
Seeing that our bikes are more valuable more than our car, we carry them in the back or our tv pickup which has a hard cover.
Antique Pedaler
'10 Flying Cloud FB
'05 GMC Pickup
X '99 27, X '05 19, X '07 23
Santana, and Ventana Tandem bicycles
Hobie tandem Kayak
I used to have a front mounted bike rack on an old VW microbus. The problem was the bike wheels could scrape pavement when I encountered dips in pavement like gas station entrances.
However, my rack was much lower to the ground than Tom's.
We usually haul our bikes inside the camper in a fork mounted rack that I custom-fashioned. Google Bike-Tite and you'll see what I'm talking about and build your own rack to go inside the camper.
i used a bike rack on my airstream for years. had three grandsons that camped with us up untill college time. never had any reason for not putting one on bumper. airstreams have a frame that the bumper mounts on.
airstreams aren't built that weak. there are a lot of airstreams out there with compartments for storage built on the rear bumper.
...However, my rack was much lower to the ground than Tom's...
As purchased, my bike rack held the bikes way too high. I had to cut 10 inches off the vertical height of the bike rack to get it as low as seen in the picture. That particular amount to remove was based on the tallest bike's wheels being no lower than the front suspension's cross member.
It was apparently the right amount as I had good visibility while on the road, and after 1600 miles (mostly interstate ) through three states, no bike wheels have been dragged.
Tom
My bikes were also too high when mounted up front so I purchased a 10" hitch drop.
WBCCI 24291
New England Unit
I purchased a rack system by Rhode Gear this year for my Ironman Canada trip with the trailer.
It is a fork down plate that sits on the floor of the trailer with anti skid rubber on the bottom. It held my road bike and nic's mountain bike perfectly still from Calgary to Penticton BC and back. I placed the rear tires on the rubber door mat and looseley tied them together with a cord. The only concern would be an exceptionally muddy bike, but I think a towel underneath would take care of that.
For 40 bucks, it was a great deal.
b.
Team Ironcops for Cancer 2006 Raced! Ironman Canada in support of the Canadian Cancer Society www.ironcopsforcancer.com
We raised over 1.3 Million dollars for Cancer Reseach this year. Great job team!!
b.
I like it! Keeps it out of the weather and road grime.
