Old 12-03-2010, 04:24 PM   #1
sherrylynne's Avatar
2007 23' International CCD
vero beach , Florida
Bicycle
I would like to take my bike with me when I tow (2006 Tunda) but everything I read here says "DO NOT" put the bike on the back of the Airstream. Sooooo, anybody have a suggestion as to where to put the bicycle? I have tried:
1. in the back of the truck --takes up too much space
2. in the camper--caused some damage plus we love to stop while traveling and cook, etc.
THANKS!
sherrylynne is offline   Reply With Quote
Old 12-03-2010, 04:37 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Bike rack on front bumper, or on top of bed cover?
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 12-03-2010, 04:55 PM   #3
dznf0g's Avatar
Oswego , Illinois
Not sure about your floor space, but I bought 2 of those front fork clamps and mounted them on a board about 3' long. I simply place the bikes in the board mount. Bungee the rear wheels together, and kinda wedge them in place in the front of the AS by the couch. Protect everything by draping blankets over them. In an emergency situation, I'm sure they would move around, but I haven't devised a suitable clamp down to the floor without damaging the carpet or walls. Front wheels go in the bed of the truck.
Old 12-03-2010, 05:02 PM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
There is a thread on here somewhere with a carrier that mounts over the propane tanks.
Hopefully someone will post it. Dave
easyride is offline   Reply With Quote
Old 12-03-2010, 05:42 PM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you use the bike fork fixtures that clamp on the side of the bed instead of the type with the bar across the bed you can save a some bed space ( I have a blue boy and spare in the bed of my 01 Tundra when I camp). If you have really nice bikes, Saris makes really good mount that uses a receiver hitch to mount. You would have to mount a receiver in the front of your truck, but they are available. My son worked at a bike shop all thru high school and college. He installed every type of rack. He bought the Saris and so did I. We have hauled bikes 1000's of miles with not problem, plus they keep the bikes from getting beaten up. They are not cheap but if you have expensive bikes it will be worth it. CycleOn Pro
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 12-03-2010, 05:43 PM   #6
2005 30' Classic
Burlington , Ontario
Hitch receiver mounted on the front of out tow vehicle to accept a bike rack has worked out very well for us - had one installed on our last three tow vehicles.
Brian.
(Our trailer - bought used - came with a 2" hitch receiver welded to the frame at the rear, I removed it.)
Old 12-03-2010, 05:47 PM   #7
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Wingeezer View Post
Hitch receiver mounted on the front of out tow vehicle tp accept a bike rack has worked out very well for us - had one installed on our last three tow vehicles.
Brian.
(Our trailer - bought used - came with a 2" hitch receiver welded to the frame at teh rear, I removed it.)
I just HATE cleaning the bugs out of every nook and cranny. A cover blocks my vision too much.
Old 12-03-2010, 07:50 PM   #8
2005 30' Classic
Well I must admit that our mountain bikes are certainly not up to the standards of serious bike enthusiasts, so for us, its not a big issue - If I feel up to it I might hose them down after a long trip but that' s about it!
Nevertheless, they have served us well and have crossed the continent umpteen times - albeit not by pedal power!
Brian
Old 12-03-2010, 08:11 PM   #9
R n B
King O D Road's Avatar
1965 17' Caravel
1961 24' Tradewind
Ephrata , Washington
We carry 2 bikes in the back of our 95 suburban. By taking the outside pedal off and turning the handles bars 90 degrees they fit into the homemade bracket quite securely. the tie down holds the bracket in place and handle bars clear the rear window with the backseat upright.
ID:	116492   Click image for larger version
King O D Road is offline   Reply With Quote
Old 12-05-2010, 12:02 PM   #10
1999 34' Excella
Ottawa , Ontario
I like to travel with my bike and found the perfect rack solution with Top Pop rails from Arvika (Arvika). Although not particularly cheap, they are top quality and very versatile - depending upon the length of the rail, you can accommodate any type or style of bike (my recumbent bicycle has a 64" wheelbase - too long for most "standard" racks) and depending upon the number of rails that you bolt on the rack, you can carry up to four bikes. I have attached the rack above the propane tanks up front - it rides high & safe and does not interfere with my hitch in any way. The best part is that the whole rack can be lifted off (it is held by a couple of pins) and attached to the rear of my tow vehicle for when I am parked at the campground and ready to drive to a trail head somewhere. Anyway, check it out - Arvika is a Canadian company but I'm sure that they have distributors in the US.
David
1999 Excella Classic 34'/Hensley
2005 Dodge Magnum R/T - 5.6L Hemi
BIG_WAVE is offline   Reply With Quote
Old 12-05-2010, 03:36 PM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
They make a rack that will fit on or above the receiver. I have a double receiver that I use with cargo trailers, but it has a 4000# weight limit.
Quite a few of us use folding bikes that can fold down close to large suitcase size.
Aaron
WBCCI #XXXX AIR #2495
Old 12-05-2010, 04:42 PM   #12
Trex's Avatar
1981 20' International
Shasta Lake City , California
Yuba Mundo cargo bike
We alway bring our bikes in the back bed of my dodge pickup.....My mundo will carry up to 400 lbs of cargo.... which means I could hook up my trailer to the Mundo bike and re-create a certain famous old photo. Trex "May Wally be with you."
Name:   yuba mundo.jpg
Trex is offline   Reply With Quote
Old 12-05-2010, 05:04 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
saw a bike rack on a Airstream that carried one bike crossways in front of the trailer and behind the propane tanks. Neat installation. The owner said he bought it from a sports store, but I do not know which one.
Old 12-05-2010, 05:15 PM   #14
2011 25' FB Flying Cloud
Anywhere & , Everywhere
I cover my bed with a painters drop cloth to protect it and lay the bike on the bed when I travel. Has worked well so far.
Al - K4GLU is offline   Reply With Quote
Bicycle on back of AS OhScottyOh Towing, Tow Vehicles & Hitches 43 02-07-2012 10:45 PM
'streaming with a bicycle jeneric Tow Vehicles 23 03-26-2010 05:57 PM
Bicycle Racks Kenyon Fun & Games 4 03-31-2008 09:42 AM
Bicycle rack tport40 2007 Safari SE 29 08-11-2007 11:29 AM
I want to ride my bicycle wheel interested Our Community 22 12-15-2003 01:35 PM
