Old 01-14-2004, 06:18 PM   #1
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
bang..bang..
last fall while out in washington state...i missed the opportunity to find out about a clam gun....can anybody explain the operation, or provide a plan to build one....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 01-14-2004, 06:25 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
A clam gun involves no explosives. It is a 3 to 4 inch diameter pipe about 36 " long. It's threaded on one end and capped. It has a T-handle welded to the pipe cap and a 1/4 " hole drilled in cap (that you can reach with your thumb).
Principle: Find a clam snorkel sticking out of sand, push gun over clam snorkle as far as you can, cover thumb hole and pull.
It is a suction device!
Screwing up your face just right whilst applying gun to clam may help process. Prayer might also be useful....
Do not try this at home!
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 01-14-2004, 06:37 PM   #3
norbert's Avatar
1993 30' Excella
Images: 24
thanx janet...so you mean to tell me this new technology works better than a shovel?
norby
