Old 07-26-2004, 07:04 PM   #1
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
bakelite
i am throwing out a question that i probably already know the answer to, but is there a bonding agent for bakelite?
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 07-26-2004, 07:34 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
norby
i've had pretty good luck with 2 part epoxy.
john
you call them ferrets, i call them weasels.
Old 07-26-2004, 07:46 PM   #3
norbert's Avatar
1993 30' Excella
Images: 24
thanx.....i tryed that but, it is on a waffle iron...i think that heat negates the fix...
norby
Old 07-26-2004, 08:00 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
norby
heat shouldn't bother epoxy.
if it is a larger part try drilling both pieces and add a pin or a threaded part of a screw to help the epoxy "grip".
john
Old 07-26-2004, 09:21 PM   #5
JohnG's Avatar
You can use JB Weld too. That is if you don't mind the gray color.
Just adding my 2˘ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-13-2004, 01:37 AM   #6
canny_banjo_man's Avatar
Yorkshire , England
John G...
I Like Yr pic of Yr A/S, but U kn U LEFT YR LIGHTS ON, no sorry they gone OFF agn, no ON...heck no OFF....I give up...U best check 'em out...U gonna B blowin a fuse or somethin ELSE...Besides U drivin the MOTHS CRAZY...LOL...Chris.....
It's NICE 2B Important...but it's more Important 2B NICE...Chris.....
canny_banjo_man is offline   Reply With Quote
Old 08-13-2004, 03:13 AM   #7
Norby, When a fastening is secured with the West system epoxy resin, the recommended method of loosening the fastening is to apply heat, such as from a hot soldering iron or a propane torch, to the head of the fastening. This releases the bond. My reference is "Wooden boat restoration and repair", published by the Gougeon Brothers, 1990, Michigan, ISBN 1-878207-14-8 , page 64, quote "At temperatures above 65 degree C, cured epoxy begins to lose its physical properties." There may be high temperature epoxies of which I am not aware.
The preferred bonding agents for Bakelite appear to be Superglue. This is referred to at http://www.holdtite.com/english/down...rod/pds024.pdf
where Holdtite recommends its adhesive Ethyl ST26 Cyanoacrylate. The company will doubtless be able to tell you what temperature it will tolerate. I would try a tube of superglue from the Dollar Store! Good luck. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 08-13-2004, 07:00 AM   #8
norbert's Avatar
1993 30' Excella
Images: 24
thanx nick,
this seems to confirm my gut feeling....as the bakelite piece is a handle attached to a beautiful over 70 year old waffle iron(art deco styling) that is still fully functional xcept that this dysfunctional idiot had to go and break and is sick to his stomach....149 degrees F. is surpassed....
