Old 03-15-2006, 11:05 PM   #1
Portland , Oregon
Backing up steep driveway-wheels under rear bumper?
I'm not sure of the grade of my drieway but I can describe it as about 20 feet high and 100 feet long. As I back the 28' ambassador up, the bumber bottoms out. How much weight can the back end support. I thought of mounting some wheels but I'm not sure of the right spot. There is a stabilizer bar about 5 feet
from the rear end. Any suggestions?
Thnx-
Wes
Wexus is offline   Reply With Quote
Old 03-15-2006, 11:14 PM   #2
funchucky1's Avatar
Riverhead , New York
OOoooh, I don't like the sound of that.
As you say, putting wheels on the bumper would decrease the friction, but they'd stick down even FARTHER than the bumper does now, so they'd add stress (weight) and do it for a longer period.
You might try keeping a couple of 2x10's around, and just when the trailer is about to bottom out, run out and put one under each tire (as you back up), to pick up the trailer an extra inch and a half...use two, offset "stepped" if you need more height.
Or, I suppose you could lower your hitch height before backing up.
Or park on the street
funchucky1 is offline   Reply With Quote
Old 03-15-2006, 11:22 PM   #3
Van
1977 23' Safari
Hillsboro , Oregon
Well, imo, you dont want the back end supporting any weight in such a situation. Are you backing up in a straight line from the street? Perhaps if you hit the driveway at an angle you wouldnt bottom out like that. Once you cleared the low point, you couldnt square up the trailer with the house.
The problem i see with mounting small wheels to the back bumper is that i would fear that eventually they would break off. As such things are want to do it would be at a bad time. Then there is the issue of having too much weight on the bumper causing it to bend out of shape.
Sometimes there are just too steep of angles to get the trailer up without causing damage. Such times call for packing the stuff to the street to load up.
As funchucky1 mentioned, sometimes a few boards is all it takes to get that extra inch of clearance that is needed.
Van
2009 F-350 FX4 Crewcab 4x4 6.4l
former '78 Argosy 20' Minuet owner
former '77 23' Safari owner
former 25' Fun Finder X-250BHS SOB owner
current 26' Komfort Trailblazer 262BSLE SOB owner
Van is offline   Reply With Quote
Old 03-16-2006, 02:17 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you have a WD hitch, you could remove the arms when you back up the hill. That should drop the rear of your TV and raise your trailers a** a little...
Richard
azflycaster is online now   Reply With Quote
Old 03-16-2006, 03:12 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I seem to recall reading in my owner's manual that they don't reccomend putting the little wheels on the rear frame, it adds too much stress when they hit, that the frame was/is designed in such a way to provide some skid protection...
Aaron
WBCCI #XXXX AIR #2495
Old 03-16-2006, 04:13 AM   #6
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Try Funchucky1's proposals. As you've discovered, a 20% grade is pretty dang severe when most acceptable grades are half that. Don't add wheels to the rear end. Park in the street or find suitable offsite storage if you can manage that.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 03-16-2006, 04:57 AM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I think I would try the suggestions given, as they are all good ones. 20%? Sounds like a good hill to go sledding in the winter.
Is there any other way to get to your place? Maybe a back alley? It may be worth the trouble to make a way in from there, if there is.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 03-16-2006, 05:10 AM   #8
87MH's Avatar
1978 31' Sovereign
Images: 292
Don't Bring the Mountain to Mohammad...
Originally Posted by overlander63
....Is there any other way to get to your place?...It may be worth the trouble to make a way in from there, if there is.
Probably way cheaper to replace the axles with 45 degree starting angles - if I recall, Wexus purchased an older trailer - it might be time to think about replacing the axles anyway. If the trailer has spring axels it would be relatively easy to raise it a couple of inches.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 03-16-2006, 06:46 AM   #9
OpenHigher's Avatar
2006 Safari SE
Los Alamitos , California
Wexus: Had the same problem when Sherry and I bought our 28 foot Safari. What I had was a gate 9 feet 5 inches with a trailer 8 feet 5 inches wide. Then I had a yard with a driveway which was at least 3 feet higher than the sidewalk, with a steep three to four foot drop from the upper level to sidewalk level.
Not good, and no solution. Ultimately, we tore everything out, the gate, the planter, all the cement (the pad was not wide enough anyway) and did the following:
1) widened the gate so when I back the trailor in I had 13 1/2 feet in width, re calculated the slope from the sidewalk, so the trailer did not bottom out, and then because the slope elongated the rv pad before I could get to level ground, I had to extend the pad further into the backyard by another 15 feet.
When it was all done I had the problem of needing new gates, so the wife and I said ok lets do it right, and had custom galvanized white powdered iron gates with Hardi siding which matches our house.
The cost, well way beyond budget.
Just had to share, but hope your wood placing method works. I would have done the same but the width of the old gate controlled by final decision.
We love our little spot for our rig, so I will post a pic here later.
Good luck, Robert and Sherry
OpenHigher is offline   Reply With Quote
Old 03-16-2006, 07:27 AM   #10
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
Wes,
After we bought our 34’ Limited I decided to have a concrete RV pad (with dump station and power) poured at the side of our house (more than 75 feet total length). The contractor did a really good job with it. However, since I had not bothered to bring the trailer home so he could see that huge rear overhang and design the drive accordingly, we had a very unacceptable slope right after clearing the curb sidewalk. For two seasons I tried to get by with planks to modify the slope but this was a real pain so I had the contractor come back and modify the drive with the slope beginning at the curb. After paying more for the modification than the total original cost it is useable. My back-in ritual is to stop a couple of blocks from home (I live on a foothills mesa that is pretty steep), remove the leveler bars and friction sway control, then when backing try to hit the drive as squarely as possible. At times I nail it without any scraping while at other times I have a slight scrape on one side of the frame.
With the extreme slope you describe I’d be as concerned for the stress on the TV as the trailer.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 03-16-2006, 07:50 AM   #11
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Another method
Thnx-
Wes
Greeting Wes~
Short of redoing your driveway or finding another spot to park your unit.
You might consider this:
Instead of trying to back it in with your tow vehicle, try to find a BOBCAT (or an old farm tractor with similar setup) with a trailer hitch mounted on the front of it. With this setup, you can raise or lower the front of the trailer as needed to avoid scrappin the rear while backing up. Airstream does NOT recommend that you put wheels under the rear frame for lifting the rear. All you'll end up doing is bending your frame, for starters. Who knows what else~
it's a problem we all face at one time or another..I ended up leaving my unit at our place in Va., as it's level ground there..lol. it's a pain in the butt because of the distance but, it works.
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 03-16-2006, 07:50 AM   #12
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Hi wexus as van said I would try driveway approach with trailer at a angle, and if that works keep an eye on your toung jack after you get trailer started up driveway you may need to use the plank idea on your TV to keep from bottoming out your toung and jack. I have a friend that has a steep driveway also and he has to back in at a angle to keep his bumber on his SOB fithwheel from hitting, and he has plenty of ground clearance so that kind of tells you how steep his grade is also for the first 20'.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 03-16-2006, 08:15 AM   #13
cameront120's Avatar
1972 25' Tradewind
If you have the budget to do this, I would suggest you create a transition slope at the bottom of the driveway. 20% slope is huge and in some places against code. A transition of, say 8 or 10%, might be enough to let you get the trailer backed up your drive without hitting the bumper. You may even need two transitions to get things to work out. A good contractor should be able to meassure your trailer and tow vehicle to determine what sort of transition will work. Good luck!
North Vancouver, BC
Leak at rear bedroom wall Kirby Stone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 02-12-2010 11:41 AM
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 08:52 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Leak in the rear JodynJeep Sinks, Showers & Toilets 10 09-08-2006 09:40 AM
