Old 10-10-2011, 07:53 PM   #15
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
On the internet I found electric add on kits for rv water heaters, called Hott Rod and Lightning Rod. Have any of you tried one of these?
Alan
Old 10-10-2011, 07:54 PM   #16
dznf0g's Avatar
Oswego , Illinois
My brother had a hott rod. Worked OK. Better than not having the electric option anyway.
Old 10-10-2011, 07:56 PM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
How complicated is the install?
Alan
Old 10-10-2011, 07:56 PM   #18
Central , Mississippi
Gee...I'm still looking for ANY switch in my '63...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-10-2011, 07:59 PM   #19
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I just ordered a new Atwood to replace my failing gas only heater. The new one is both gas and electric. As I understand it, essentially a "hot rod" type unit is built in.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-10-2011, 08:02 PM   #20
dznf0g's Avatar
Oswego , Illinois
As I recall, you remove the drain plug and screw in the Hott Rod. It's been a long time, but I think the thermostat is internal to the rod and you just plug it in. You probably will have to run AC power at least close to the H2O heater tank.
Old 10-11-2011, 07:23 AM   #21
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
The new "Hott Rods" have an external temp probe which must be mounted directly on the tank. The instructions specifically state not to mount on the pressure relief valve. That is the primary reason I returned the one I bought, and part of the replacement decision.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 10-11-2011, 05:36 PM   #22
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I went to the Hott Rod manufacturer's website to read the install instructions. The tank insualation has to be removed from a fairly large spot to mount the thermostat.
Alan
Old 10-11-2011, 09:28 PM   #23
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
I've been banging my head over the same thing, Shane.
I've never found an electric-switch option. The manual only confused me more. One streamer has both, but says the electric version isn't worth a patootie anyways; he said it doesn't get hot enough.
I just got home from shake-down cruise; the propane heated the water so well that I turned it off as soon as it got hot, and 4 - 5 hrs. it was still hot!
When I take trailer to dealer to dewinterize, I'm going to get the electric-switch option straight. To tell you the truth, I don't really care if I have it or not. I'm happy with the propane version only.
Fly at Night is offline   Reply With Quote
Old 10-21-2011, 03:13 PM   #24
2004 30' Classic
Hillsborough , New Jersey
hot water heater
The advantage having both an electric and gas hot water heater is:
1. When you are plugged into shore power you can heat the water as part of the "rent" to stay at the site
2. If for some reason the gas doesn't work you can use the electric anyway.
3. The electric heat unit does not have any hot exhaust on the outside. If you have young kids around you don't have to worry about them touching the hot exhaust pipe. wolf146
wolf146 is offline   Reply With Quote
Old 10-21-2011, 04:20 PM   #25
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I had one of the add on hot water heaters. The thermostat was not glued to the tank and did not work properly. The wiring looked cheap and not safe. I took it off after it overheated the tank badly several times. When I replaced the WH I got one with the electric also. Whe have only used it once or twice on electric.
Old 10-21-2011, 05:08 PM   #26
2010 27' FB Classic
N/A , Texas
In addition, there is no noise when the electric is heating the water. I like the dual setup.
Dometic RM100 AC heater, big trouble Jim in Pima Refrigerators 15 09-30-2011 10:53 AM
'69 Overlander Fridge: RM 2500 gas electric edglenn Refrigerators 1 09-07-2011 10:09 AM
Fridge not working with Gas, still works w/electric Tim_S Refrigerators 3 09-02-2011 05:06 AM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
On Demand Water Heater? codybear Water Heaters, Filters & Pumps 4 06-04-2011 10:27 AM
