Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 07-06-2007, 04:41 PM   #1
MJBear
Profile:  2007 25' Safari FB SE
Bemus Point , New York
Airbags on an airstream?
Has anyone heard of putting airbags on an airstream trailer? There is a 30' classic for sale and it looks like a nice trailer but the owner installed airbags under it. He states he raised it up 8" so it has better clearance. Does this sound like a good idea? Seams like it would change the center of gravity. Otherwise the trailer may be what we are looking for and in the right price range.
MJBear is offline   Reply With Quote
Old 07-06-2007, 06:41 PM   #2
Alumatube
Alumatube's Avatar
Profile:  Jefferson , Arkansas
There was a thread on this trailer a few days ago, but I can't find it right off the bat. I believe the overall consensus was it was not a good idea.
Queston to the list: Could the airbags be removed and the trailer be returned to "normal" without a lot of work?
(I found the thread: http://www.airforums.com/forums/f273...bay-33727.html)
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
1974 31' Excella (soon-to-be carhauler)
Alumatube is offline   Reply With Quote
Old 07-06-2007, 06:47 PM   #3
Airhog1
Airhog1's Avatar
Profile:  1975 31' Sovereign
Searcy , Arkansas
I think this was in the ebay scam thread if I remember right...
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 07-06-2007, 08:48 PM   #4
MJBear
It doesn't look like a scam, it's on rvtrader.com for 48,000. Looks for real.
Old 07-08-2007, 06:09 AM   #5
jwhitmer
Profile:  2005 30' Classic S/O
Massillon , Ohio
Air Bags on a Classic
This happens to be my ad. I was tipped by another member of your forum last night so I wanted all to know the bags work very well, thank you. My classified ad gives more details. They were first added to give me clearance on my drive, but have other added benefits. I did have extensions welded to my stabilizers due to the 8" of added height, but they are almost not noticed. Call me at 330-837-9412 if interested or if you wish to have it done to your trailer. I was never concerned about hitting bottom at any campground, after it was done and it pulls great. My only need is more interior space.
jwhitmer is offline   Reply With Quote
Old 07-08-2007, 06:47 AM   #6
overlander63
overlander63's Avatar
Profile:  .... , California
John, many of us here would want to revert the trailer back to its original configuration, as the added height may cause stability issues. Do you know if this can be relatively easily done, or if it would be a major project?
And welcome to the forums.
(that guy from Inland RV)
Old 07-08-2007, 08:39 AM   #7
jwhitmer
Massillon , Ohio
Air Bags
I would not even consider changing it back. The weight is low and actually gives the trailer a lower center of gravity than it had before. I have pulled the trailer about 8,000 miles since having it done and it trails very well. See the Kelderman Manufacturing website at Keldermanairride.com for details.
Old 07-08-2007, 09:49 AM   #8
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I saw the ad also, and find this an interesting concept. I would think that this would be a very handy capability, especially if you had an on-board compressor to inflate the bags when you need clearance, and deflate them when running on the highway.
Looking at the picture of this unit in the ad, I can not see how the center of gravity could be lower when it is jacked up 8" without adding sprung weight to the bottom of the trailer.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 07-08-2007, 11:30 AM   #9
jwhitmer
Massillon , Ohio
Air Bags
I must clarify my last post by saying that I did not find any handling problems with my trailer after increasing the height due to the air bag addition. It trails very well and I might add the original suspension was not taken off, but better shocks were installed. I suppose the center of gravity was changed slightly, however it was not noticed. I just loved the increased clearance which it gave me and items inside did not travel to the extent they originally would if left on the counter or table. It was a very worthwhile addition.
Old 07-08-2007, 12:09 PM   #10
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
THis seems like a very bad idea. Raising the center of gravity is bad. The axles were not designed for this setup. It is really not changing the ground clearence since the axle is still the same distance from the ground. It does change the attack and departure angles.
Michelle
I'm not afraid to drive. I learned in Washington, DC
Sarah and Snowball
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 07-08-2007, 12:15 PM   #11
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Kelderman's web site states differently.
They say 3 inches rise, not 8 inches
They also say Installation of the suspension lifts will raise the center of gravity of the vehicle, causing the vehicle to handle differently than stock. It may increase the vehicles susceptibility to a rollover, on road, off road, and at any speeds.Extreme care should be taken to operate the vehicle safely at all times to prevent rollover or loss of control resulting in serious injury or death.
Doesn't sound to me as a very safe trailer to tow.
If Airstream stated the above cautions, they would be out of business pronto.
It also appears from the photo's, that indeed, the trailer is raised so that the back and front ends are higher, but the ground clearance remains the same since the axle tube heighth does not change.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 07-08-2007, 12:23 PM   #12
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I’m going to have to go with Andy on this one. I can see an advantage if you could raise it for certain obstacles and then return it to the normal height for towing, like the old Citroëns. Or like some lowriders, you could tow slow humping up different sides.
Vaughan
Old 07-08-2007, 12:40 PM   #13
jwhitmer
Massillon , Ohio
Excuse me, if I did not use the correct terminology. I did increase clearance where I needed it by 8 full inches. This was at the bumper and the hitch. My drive is steep so this is where I needed it and the Hensley hitch was always very close to the ground. Of course the axles are at the same place. The reason my installation is higher was due to the location of the tanks. The installer had to stay above them. All I can say is from experience and at 65 to 70 miles per hour, I've had NO PROBLEMS!
Old 07-08-2007, 01:25 PM   #14
Commercial Vendor
Please try riding in the rear of that trailer at those speeds.
That's the "real" test for stability.
What happens to the tail end of an Airstream "seldom" can be observed from the drivers seat.
Thousands of test miles prove that.
The ground clearance, in fact, has been effectively lowered because of the additions to the chassis system.
Also, if those shocks are vertical shocks, their effectiveness has been compromised by placing then in a 45 degree angle.
The sales attraction for the trailer, as it sits, is about nil, at least to the very knowledgeable Airstream owner, and most of them are.
On the other hand, if you removed all the "stuff," that trailer would probably sell very fast, if the price was reasonable.
These are just the simple facts of Airstreaming.
Inlandrv.com
800-8777311
Airstream vs. Avion? 68 Suburban Vintage Kin 29 11-21-2008 08:35 AM
Cost to restore a gutted Airstream Draco General Interior Topics 19 02-06-2007 02:04 PM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 02:39 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 03:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 02:31 PM
