Old 06-15-2012, 01:10 PM   #1
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Air Forum Update Needed
Is there any chance the "Quick Links" box in the top right side of the guest page can be moved over to the left so that it does not activate every time my mouse crosses it after returning the page to the top????
Why, when not signed in, when my mouse activates the box "JOIN NOW its FREE" I am invited to join a "FOREST RIVER FORUM"??????
Dave
Old 06-15-2012, 01:33 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Better yet is there a way to get rid of it altogether? It is a first rate pain.
2004 Excursion 4x4
Old 06-15-2012, 01:40 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Don't you have a scroll wheel on your mouse? 21st century technology will fix that for you...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-15-2012, 07:38 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Thumbs up One of the "Supporting Member" Benefits...
If you are talking about the "Page Peel" and are a "Supporting Member" (gold rivet) go into your "UserCP" > "Edit Your Details" then scroll down to the bottom and check the box in the "Remove Page Peel in Upper Right Corner" section (last boxed section).
If you aren't already a supporting member, go to the same place and it tells you how to become one.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 06-15-2012, 09:10 PM   #5
masseyfarm's Avatar
Images: 56
No Shari, I am talking about that Blue Box (QUICK LINKS) hanging off the back of that trailer on the right top of the page. It is there also after you sign in and because of the location, when I drag the cursor across it, it opens when not wanted. It would be better located to the left, with the other selection boxes.
The page peel was also a PITA but I did get it under control.
Dave
ps: maybe it is the rain and cold that is making my owly.
Shari
Old 06-15-2012, 10:43 PM   #6
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Thanks for pointing out the Forest River text - we'll get that fixed. You can avoid the 'Join' window by logging in
As for the quick links tab.... well... we put it there because several folks asked. It you just keep your mouse moving however, it will close once you move past that area but your comments are noted and I'll pass them along.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 06-15-2012, 10:52 PM   #7
purman's Avatar
1968 28' Ambassador
Question? why is your mouse in the upper right corner? My mouse stays clear of that area, it doesn't like the (quick link) box, and so never ventures there unless forced to by it's master.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-15-2012, 11:07 PM   #8
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
Gee, as a newby my "mouse" - the cursor from my trackpad - seems to always cross the "Classifieds" which seem to always pop up right after I open a new tab (I stay "signed on.")
"Pretty clever of those mods..." I thought. So, BURST MY BUBBLE!
OilnH2o is offline   Reply With Quote
Old 06-16-2012, 07:52 AM   #9
purman's Avatar
1968 28' Ambassador
Ok, it must me me but I never have had this problem and I'm kind of jealous about it. Maybe I need to switch from a macbook pro using safari to the pc and conventional windows explore. maybe than I could have this problem. Is this how you get these glorious pop up and pop open windows. do you have to use a pc? is there something over there that i'm not using? because I'm never over there.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-16-2012, 08:15 AM   #10
HowieE's Avatar
Images: 12
Originally Posted by Janet View Post
As for the quick links tab.... well... we put it there because several folks asked..
Did they ask for the function or the location. Those of us that use the scroll bar to drop down on the page cross it ever time we go to or leave that corner of the page. If you go to retrieve a PM you cross it. Would it not serve the same needs of those who asked for it if it were moved to the left. That would put it to the left of the rear tire of the last trailer in the header giving clearance enough to remove the problem.
2004 Excursion 4x4
Old 06-19-2012, 01:42 PM   #11
mefly2's Avatar
2015 25' FB Eddie Bauer
Dave
LOL; we got rid of our Forest River product - don't want to go back there ... not funny, however, if it is annoying you ...
Old 06-19-2012, 03:25 PM   #12
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Now, now... careful with the OS proselytizing.
In Safari on OSX Lion those tabs pop open if you mouse over them, just like they do in Chrome in Windows (or OSX). It's just a question of how you navigate around the screen. I use page up/page down more than the mouse and don't have issues with those tabs opening unexpectedly on either platform.
— David
Old 06-24-2012, 02:00 PM   #13
HowieE's Avatar
Images: 12
I think I will stay with the nonsence of the Quick Ling getting in the way every time I approach the upper right corner of the page. However I could give up on the young blonde pictured and appearing in place of the Martini ad asking to be my friend and only 2.5 miles away. I thought this Forum had just a bit more class than that.
I must be projecting the wrong image to Google with my trailer searches.
2004 Excursion 4x4
Old 06-24-2012, 02:17 PM   #14
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
Howie, I've never seen the young blonde. I would like to though. Maybe she is a function of your thread choices........I must be doing something wrong.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
