Old 11-06-2008, 06:24 PM   #1
The Silver Schooner
Pudentane's Avatar
2007 28' Safari SE
Dover , New Hampshire
air compressor recommendations?
I need an air compressor to blow out my plumbing lines for winterizing - and thought one that I could also inflate a low tire with would be a good idea - since I plan to do a lot of boondocking. So I've been looking at 12 volt ones - Sears has a craftsman model for about $45 - but it got very poor customer reviews. Does anyone have any recommendations? - price is a factor - but doing the job and being reliable is more important.
Louisa & Jasper Joy
Pudentane is offline   Reply With Quote
Old 11-06-2008, 06:42 PM   #2
1973 31' Excella 500
Morristown , Tennessee
I personally have never had a 12 V compressor that worked well. I would favor a pancake unit but would be interested in anyone's recommendation for a good 12 V model.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Old 11-06-2008, 07:02 PM   #3
Images: 59
Here's a previous thread. I think you will need a tank to be able to build up enough volume to blow out the plumbing lines. Maybe a 2 - 3 gal tank you could leave at home.
Old 11-06-2008, 07:06 PM   #4
2004 34' Classic S/O
Huntsville , Alabama
Smile Compressors
I have an F250 and I have hot wired a 700 amp AC inverter to the battery so I have AC power in the cab. I normally use the inverter when the engine is running
Too the subject, I have never had a 12volt compresssor that was worth its salt. I found a small, 50 dollar compressor in Lowes a couple of years ago and it ramps up well and while it takes a little longer to fill up tires it works quite well off the inverter.
I also had a slightly larger compressor that also worked off the inverter but because of size I decided to go with the smaller unit. If you limit your pressure you can blow the lines (winterize) with no problem.
Both of these were smaller and lighter than the traditional pancake compressor. While the inverter is a little more cost it also is used for computer use, GPS use and telephone recharging. Good luck. PS we have had these compressors for almost ten years. fjs
fschmidt1 is offline   Reply With Quote
Old 11-06-2008, 07:14 PM   #5
kittrik's Avatar
1960 24' Tradewind
mount wolf , Pennsylvania
Try ridetech.com. They have the compressors the hot rod guys use for air ride suspensions. I put air ride on my 60 tradewind and have been using one of thier compressors for years. Always use an external pressure cut off switch, they are not built into the compressor.
kittrik is offline   Reply With Quote
Old 11-06-2008, 07:19 PM   #6
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I have a small Coleman 110v compresser. I don't have it here so cannot give the model #. It is about 6x6x15 inches. It is somewhat slow to inflate tires but vastly superior to a 12v unit.I carry a Honda 2000 generator when I camp,so I always have air. Adios, John
Diesel1 is offline   Reply With Quote
Old 11-07-2008, 07:20 AM   #7
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
I carry a Q-Industries-MV50-SuperFlow-Compressor that I actually picked up at Costco for < $50. Smallish, seems to work well.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 11-07-2008, 08:29 AM   #8
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Cheers,
-jd.
Yes, I have one too. It's outstanding compared the smaller models. However, it requires a direct connection to the battery.
Ahab is offline   Reply With Quote
Old 11-07-2008, 08:42 AM   #9
99Limited34's Avatar
1999 34' Limited
Darien , Wisconsin
We wired an inverter in our F-250 as well and carry our Cambell-Hausfeld 110 V compressor in the back of the truck, never had any luck with 12V ones.
1999 Airstream 34' Limited (The Cottage)
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
99Limited34 is offline   Reply With Quote
Elec. Compressor recommendations? frozen chosen Our Community 7 08-17-2004 08:20 PM
Air compressor for AS... crazylev General Repair Forum 4 05-11-2004 07:41 PM
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 12:58 PM
Air compressor ALANSD Airstream Motorhome Forums 15 01-02-2004 04:18 PM
Air compressor Craig Winterizing, Storage, Carports & Covers 4 11-07-2002 08:21 AM
