Old 05-20-2008, 01:12 PM   #1
2005 22' Interstate
Afton , Virginia
Aftermarket Miles Per Gallon Gauge
I ran across this gadget while surfing recently. Here's the URL:
ScanGauge review: Save gas by adjusting nut behind the wheel
The article seems very positive, but it is preceded by something suspicious;
"Run your car on water...", so I am a little hesitant about the whole thing.
Has anyone had experience with this device?
regards
herrgirdner is offline   Reply With Quote
Old 05-20-2008, 03:11 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
A vacuum guage will do same thing,the more vacuum you are pulling ,the better gas milage you are getting.Or pretend you have an egg between your foot and the gas pedal,if you don`t break the egg you should be getting good milage. Dave
easyride is offline   Reply With Quote
Old 05-20-2008, 04:16 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
regards
These were at the heart of a scam to use acetone as a fuel additive to increase your fuel mileage, along with a few other such 'snake oil' type devices. Google 'acetone fuel additive' an see what I mean. I even tried it for a while....and my mileage actually went DOWN!.
While the SG II will probably give you an instant read-out on your mileage, it is just that......'instant' and usually doesn't apply over the long run. I use the fool-proof method: miles driven divided by gallons used. Can't go wrong...
Old 05-20-2008, 04:19 PM   #4
2011 25' FB Flying Cloud
Anywhere & , Everywhere
I use an even easier method - I ignore gas mileage. In my mind driving a full size pickup and towing a travel trailer is not consistent with worrying about fuel mileage.
Al - K4GLU is offline   Reply With Quote
Old 05-20-2008, 07:43 PM   #5
2005 22' Interstate
Afton , Virginia
Yeh, Lew, I keep a history of my fuel consumption on all my vehicles, and also log tire rotations, oil changes, etc. But, since I own a Prius, I have grown to like the realtime consumption meter. It's almost as accurate as the logbook.
tks
and regards
Old 05-20-2008, 08:02 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Can I at least use a hardboiled egg?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-20-2008, 09:18 PM   #7
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If you want to get something like this, you can just get a vacuum mileage meter and mount it on the dash. The higher the vacuum, the better the mileage.
Old 05-20-2008, 09:46 PM   #8
2005 22' Interstate
Afton , Virginia
I agree with you about the vacuum gauge, but wonder how it would work on my 5-cylinder turbocharged diesel. I think plugging something into the diagnostic port would be simple enough for even me.
I just wondered if anyone has tried it the SGII.
regards
Old 05-21-2008, 09:48 PM   #9
Vintage Kin
Fort Worth , Texas
I see the Scangauge used quite often on boards oriented towards diesel and gasoline performance. I think it would be a nice toy to have.
Old 05-22-2008, 04:32 AM   #10
Airstreamer67's Avatar
My old 1996 Powerstroke diesel doesn't have the electronics needed to use a scan gauge. So, I keep an eye on my exhaust-gas temperature and boost gauges. These show how much fuel the engine is burning (EGT = heat produced through fuel burn) and how much demand is being ordered-up at any given time (turbo boost = demand for power). The lower the readings, the better for mpg conservation. They replace the vacuum gauge I used to use on a gasoline engine.
Airstreamer67 is offline   Reply With Quote
Old 05-22-2008, 09:43 AM   #11
2005 22' Interstate
Afton , Virginia
Rednax:
Since this topic does not appear to be of general interest, could you please PM me the URL(s) of the forums where the SGII is discussed?
Tks
and
regards
Old 05-22-2008, 09:32 PM   #12
Vintage Kin
Fort Worth , Texas
Rednax:
Tks
and
regards
PM coming your way after a search.
6 gallon?....10 gallon?.... FreshAir Water Heaters, Filters & Pumps 16 06-15-2007 05:57 PM
Miles per Gallon? Phil Gobie On The Road... 52 12-21-2006 07:56 PM
Dealer/Aftermarket Hitch Equipment Toasty's Dad Hitches, Couplers & Balls 12 12-02-2005 01:18 PM
The Gallon.. canny_banjo_man Off Topic Forum 5 08-15-2003 01:19 PM
The QUEST for 20-25 Miles Per Gallon Mr Jody Hudson Tow Vehicles 32 08-04-2002 06:16 PM
