Old 08-16-2006, 07:34 PM   #1
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
3-prong plug converter to fit in regular outlet
Does anyone know where I might find a converter plug for our 30amp trailer outlet plug that would work in a regular outlet?
codybear is offline   Reply With Quote
Old 08-16-2006, 07:40 PM   #2
TIMEMACHINE's Avatar
Huntington Beach , California
Yes
Easy answer: Walmart, they have a small RV accessory section, usually near sports and/or automotive.
TIMEMACHINE is offline   Reply With Quote
Old 08-16-2006, 07:41 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You are talking about a 30 amp RV to 15 amp adapter. You can get these at any RV store, CW and maybe even Wally World. I got mine at CW for a few dollars.
Richard
Old 08-16-2006, 07:42 PM   #4
2006 28' Classic
Lake Tomahawk , Wisconsin
Look in or at Camping World on line or catalog.
Item # 24494 30 amp Male to 15 amp Female. All of $2.99
Have fun!
William Ales is offline   Reply With Quote
Old 08-16-2006, 08:21 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
and don't try to run your airconditioner on it!
john
you call them ferrets, i call them weasels.
Old 08-16-2006, 08:31 PM   #6
1973 31' Sovereign
Portland , Oregon
Images: 22
I found adapters at both Home Depot and Lowes.
malconium is offline   Reply With Quote
Old 08-16-2006, 08:51 PM   #7
JimGolden's Avatar
1977 31' Excella 500
I bought mine at Lowes. I wired 20amp circuits in my house and it would power the a/c. I'm not sure if it was weak due to the 20 amp circuit, or because I had a 12 wire extension cord. But, I wired in two proper 30 amp RV plugs on 30amp 10 wire to my panel and....the AC will now freeze out a polar bear!
Best thing is to wire up an actual 30amp circuit to an RV plug. You won't regret it!
- Jim
JimGolden is offline   Reply With Quote
Old 08-16-2006, 09:46 PM   #8
codybear's Avatar
1964 22' Safari
Images: 315
Thnx for all suggestions..now since I admit I'm not electrical /hi-tech savvy, could anyone post a photo of the plug? please!
Old 08-16-2006, 10:06 PM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
I could repeat it a 3rd time -- but will instead say if you need the A/C to use as a guest house, hire an electrician to put in a 30A circuit near where your trailer will be parked.
Me? I use the 15A adapter all the time and it helps me getting my Safari ready for the road, topping off the batteries, cooling down the fridge before a trip, etc. Enjoy!
5 meter Langford Nahanni
Old 08-17-2006, 01:10 PM   #10
1973 31' Sovereign
Portland , Oregon
Images: 22
I have not really even tried to run my air conditioner yet. I use the adapter so that I can get some 110 to my AS outlets so I can run power tools during the remodeling process that I am in now. That seems to work OK with a heavy duty extension cord plugged into a 15amp outlet on my back porch.
Malcolm
Old 08-17-2006, 02:53 PM   #11
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
you can never have too many adapters
We discovered that you can never have too many adapters. We thought we had it covered...all that we could possibly need. But a week ago we checked into a campground with our little Argosy Minuet, and found that they only had 50 amp and 15 amp at their sites. We had to make a quick run to WalMart to buy a 50 amp to 30 amp adapter in order to use the AC and microwave safely.
$17.32 We could have rented one for $4.00. Has anyone else ever had to do the 50 to 30 amp adapter?
ID:	24863   Click image for larger version
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 08-21-2006, 06:00 PM   #12
codybear's Avatar
1964 22' Safari
Images: 315
adapter update
We were able to find the adapter plug: only cost $2.50 at a RV sales place..thnx for the help!
Old 08-21-2006, 09:00 PM   #13
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Loudruff,
"Ha, ha. We only have 50-amp and 15-amp, but if you have the most common connector and common need for 30-amp service out there in RV-dom, we'll rent you this adapter for only $4."
Please. I think I might have had a suggestion or two for them.
Has anybody else run into this?
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-21-2006, 10:00 PM   #14
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yes, a park i stayed at had 30 amp outlets in every other pedistal. the rest were the 15/50 type.
i guess a 50 to 30 dog bone is in my future.
john
Rear TV Antenna Outlet lbrodsky 2001 Safari 11 12-15-2002 03:37 AM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 07:52 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 09:45 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 11:48 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 09:54 AM
