Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 12-10-2002, 04:31 PM   #1
manley
Profile:
Post WTB Used tires for Argosy MH
I've been limping around the Gulf coast on the rubber that was on my 28 when I found it 3 years ago. Finally dry rot has taken over. I'm think about used tires as opposed to new in order to save some $$, especially considering it gets driven less than 1000 miles annually. I think the size is 8 R 19.5. Found a set on ebay, but think the auction closed before I could confirm the size would have fit. I think they went for $250 for 6.
Any suggestions? One of you members wanna replace your's with new tires? Also, someone suggested a different type on the front.
Thanks, and please post response or send me a private e.
Manley Cummins
Spanish Ft. AL
'77 28' Argosy MH
Manley
manley is offline   Reply With Quote
Old 12-11-2002, 10:00 AM   #2
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
I copied your post to the motorhome area as it will probably get more attention here.
Also you might read some of the " tire" posts, by putting tires in the 'search' area, there are some really good discussions on this subject. It is too easy to get hurt by saving a few dollars on tires, as you will probably hear from others who have experienced that.
Old 12-11-2002, 12:23 PM   #3
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Wouldn't buying used tires be just buying someone else's problem?
Have you seen the thread:
A tale of woe - how I saved a buck on tires...
Just my 2-cents ~
Shari
InsideOut is online now   Reply With Quote
Kelly Tires for MH....any thoughts? 1985air345 Airstream Motorhome Forums 6 02-22-2004 10:05 AM
8 x 19.5 MH tires smooth or treaded? Astrodokk Airstream Motorhome Forums 3 11-15-2003 09:52 AM
Questions about trailer tires... cactushead Tires 2 10-22-2003 06:58 PM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 03:10 PM
325 MH Tires? TRAPEZE Airstream Motorhome Forums 0 07-03-2002 06:08 PM
