Old 10-13-2007, 08:39 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Wiring advice
I have one marker light that does not work. I could not get power to the fixture so I pulled the connector out and found one wire was not crimped down enough to hold the wire in. I removed the wire from the connector and then put a volt meter to the black and white wires. I don't get a reading. My question is, are the two wires hot? or is one a negative and the other a positive. Most RV's just use one wire for hot and the ground is the RV. Appreciate any advice on 12 volt power to the fixture.
Steve
spat61 is offline   Reply With Quote
Old 10-13-2007, 08:43 PM   #2
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
Steve
take the fixture off and replace w/ another from your rig.
see what happens.
light man
Kevbo10 is offline   Reply With Quote
Old 10-30-2007, 12:57 AM   #3
Pup Rivet
ftbjc's Avatar
1984 31' Airstream310
Wichita Falls , Texas
You did not say where the marker light was located. I replaced all of the overhead markers (5 amber and 5 red) on my 84 310 with the LED type. They all had one wire coming through the MH skin and the other wire was short and connected to one of the mounting screws as a ground compleating the circuit. The front and rear markers on each corner of the MH are mounted in fiberglass farings and require two wires to make a circuit. Try reconnecting the wires to the fixture and then, If you have a gage connect one lead to the black wire and the other lead to the frame. Check to see if you have any current, if not connect to the white and try again (make sure you have your lights turned on and the bulb is good) if there is current then chances are that the ground wire is defective and needs to be repaired or replaced.
Fred
84 310 Limited Motorhome
"It's when we think we know it all, that we have the most to learn"
ftbjc is offline   Reply With Quote
Wiring advice for tow vehicle Taffy Mechanics Corner - Engines, Transmission & More... 0 09-15-2004 06:00 PM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
re-wiring drex Electrical - Systems, Generators, Batteries & Solar 9 05-18-2003 09:26 AM
AV Wiring Neenm Electrical - Systems, Generators, Batteries & Solar 6 09-20-2002 06:54 AM
