Old 09-21-2004, 03:44 PM   #1
1976 28' Argosy 28
Lansing , Michigan
Windshield wipers
Probably another dumb question, but I can't figure out how to switch on the passenger side windshield wiper. upon looking under the hood, it appears that both sides work independently. I this correct and if so, which knob operates each wiper. To the left of the steering wheel, I have a wiper knob and a washer knob. Also, my washer is not working. Any suggestions? Thanks again, everyone!!!!!!! You guys are great!!!
tandemfish is offline   Reply With Quote
Old 09-21-2004, 07:06 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Mine has two knobs one for each wiper. The left knob for the left,etc.
As for washers it is common that the hoses are shot, or the nozzles are plugged up or both.
Go under your hood and find where the rubber hoses tee together, and then go into the bottle. If you disconnect the tee, and have someone press the washer button, it might spray some out of the line. You can isolate where the problem is. If it does shoot out some, then you know the nozzle or hose endis plugged and compressed air might clean it out. If not the pump may be shot. See if it makes a sound when it is supposed to be pumping. Mine has bad hoses. I bought a long squeegee and keep the windows pretty clean with that. The washers were low on my to do list.....and after 3 years I haven't gotten to them yet
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-06-2004, 08:56 PM   #3
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Mine also has two knobs on the left of the steering wheel, one for each of the wipers. The washer works while the wiper is turning and you have to push it in almost like a pump, although i found out it's actually electric.
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Clear your windshield 74Argosy24MH General Motorhome Topics 0 01-28-2004 08:06 AM
dot no for windshield glass wb13798 Mechanics Corner - Engines, Transmission & More... 7 01-22-2004 08:42 PM
Windshield Wipers Running AccessMaster General Motorhome Topics 3 04-07-2003 08:15 PM
windshield wipers 350 LE classic 1992 dbyar Mechanics Corner - Engines, Transmission & More... 6 12-21-2002 12:56 PM
