Old 11-10-2003, 10:30 PM   #1
DaveJ's Avatar
Window Seals on '92 LY MH
Hi,
It looks like every window on my used motorhome (just bought it a couple months ago ) need some weatherproofing repairs.
Does anyone know what approach to fixing this I should take? I wouldn't want to have to replace the windows unless it's a last resort. Is this something that one can fix themself?
My way of fixing this would be to inject some silicone caulking into the gaps but I don't know if that's a bad thing or not. Never had an RV to repair before so I'm green at this kind of stuff but willing to learn new things.
Thanks.
Dave
DaveJ is offline   Reply With Quote
Old 11-11-2003, 05:08 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Dave,
I would start at an Airstream or RV dealer. I am sure the seals can be replaced. I have done it on my MH in the past. It is all a matter of gettting the right stuff.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 05-04-2004, 02:56 PM   #3
phred's Avatar
Dave;
I just did my front passenger window on a 95 35' Land Yacht. That rubber molding is starting to shrink and the rounded courners are starting to pull away. I started at the bottom of the window and used a very small screw driver to pry upwards at a 45 degree angle to the glass. the molding will pull up and then will pull relatively easily around the window. Clean out your tracks and weep holes so the water that gets in the tracks can get out. There are weep holes on the outside and then weep holes on the track in back of the outside.
To put it back in, start at the end on the bottom and place it against the window abutment (where before it may have shrunken away). Get the back against the glass and then push down and in at a 45 degree angle. Go around the window and have the "shortness" where time did the shrinkage, placed at the top of the window. The molding went back in tightly and I did not need any caulk to hold it in place. If you caulk it will just screw up the water channels for drainage.
Let me know how you make out or if you have other questions!
Fred
phred is offline   Reply With Quote
Window seals joelforeman Classic Motorhomes 37 04-25-2019 04:27 PM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
