Old 11-01-2015, 02:29 AM   #1
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Window
Hello everyone,
On Saturday I started to control all the windows of the motorhome, you can open and close properly, and discovered the driver's window and front passenger window lock, do not go.
question, the lock window are different from those found in at rear?
if they are different I think if I would miss the front, someone knows where you get that ?, I put the photo does not pass
thanks
Herman
german6563 is offline   Reply With Quote
Old 11-01-2015, 04:58 AM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
They are different from the rear ones Herman, and even different from the road side to curb side.
Airstream supply have (used) curb sides in stock (Motorhome Window latch CS) but not the ride side. I believe you will only find them used as I haven't seen them for sale still new.
martin300662 is offline   Reply With Quote
Window Replacement New Window Gaskets pawnguy Windows & Screens 12 09-05-2017 10:17 AM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 06:32 PM
Replacing Nylon Window Guides - not holding window up Tom Bray Windows & Screens 5 06-16-2008 06:52 AM
