Old 12-24-2013, 04:51 PM   #1
2000 31' Excella
Ontario , Canada
Where to mount CB antenna
I have a fibreglass/aluminum coach. Any suggestions on where to mount the antenna and how??
woodytwo is offline   Reply With Quote
Old 12-24-2013, 05:55 PM   #2
2005 19' Safari
GLENDALE , AZ
What kind of antenna do you have? Some need a metal ground plane, others do not. Antenna type determines whether you can install the antenna on fiberglass, or whether it needs to be mounted on something metal. Please, provide details on brand, model, etc.
Old 01-16-2014, 07:19 PM   #3
JMSx2's Avatar
2005 30' Land Yacht Gas 30
Belgrade , Montana
The previous owner installed the antenna on the passenger window. I'll be home in a couple of weeks and send a picture.
JMSx2 is offline   Reply With Quote
Old 01-17-2014, 01:26 AM   #4
2005 19' Safari
GLENDALE , AZ
Note: "trucker" antennas can be mounted on the mirror arms, ladders and other metal parts. If you want to mount on fiberglass, look for a marine "dipole" antenna, which does not need a ground plane. Radioshack used to carry marine antennas; otherwise, check marine stores, like West Marine (Boat Parts, Boat Accessories, Sailing Gear and Boating Apparel from West Marine).
Old 02-18-2014, 06:09 PM   #5
Registered User
1996 32' Cutter Bus
Petaluma , California
Images: 34
Where to mount cb antenna
Name:	ImageUploadedByAirstream Forums1392772099.737389.jpg
ID:	205889 There's mine. It's on the street side in the front. The previous owner had installed the CB radio. The CB is mounted right before the dashboard below the drivers side window.
AdamB is offline   Reply With Quote
Old 02-18-2014, 07:44 PM   #6
JCPOTTERF's Avatar
1963 28' Ambassador
Danielsville , Georgia
Really, a C B radio ? I have one but its been packed away for 20 years i think ill get it out set it up and give a big 10 4 rubber duck to that !!!
JCPOTTERF is offline   Reply With Quote
Old 02-18-2014, 08:35 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
WBCCI swears by them (at them? on them?) for keeping caravaners in touch with each other. With a CB, you're broadcasting to all in range, and you don't need to try to set up an umpteen-way conference call on a cell phone while the vehicle is in motion to people whose numbers aren't in your speed dial.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Sat Radio Antenna mount and install DandB^2 Audio, Video & TV 15 04-01-2008 02:05 PM
Flush Mount or Surface Mount Skycop Water Heaters, Filters & Pumps 10 01-13-2008 06:59 PM
Antenna Mount Chaplain Kent Audio, Video & TV 3 06-12-2005 05:05 PM
70's am/fm antenna mount Safari Tim Audio, Video & TV 8 12-08-2004 12:57 PM
Stainless Steel Antenna Mount on AS Body gklott Electrical - Systems, Generators, Batteries & Solar 2 11-17-2003 11:00 PM
