06-02-2010, 05:30 AM
1972 23' Safari
NSB
What's your interstate speed
We're taking our '75 26 Argosy MH on it's longest trip to date since we got her. All mechanicals have been tended to: tune up, carb rebuild, transmssion service, coolant flush, remote air cleaner, fuel sender rebuild etc. This will also be the first trip where we will be on the interstate instead of local state roads.
So what's your comfortable and efficient interstate cruising speed? I'm assuming there's an MPG drop as some speed...somewhere in the mid 60's?
thanks
06-02-2010, 05:36 AM
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
Usually 65. May be a little higher or lower. I get around 12 MPG with the Chevy and 13.5 with the Ford.
Annette
06-02-2010, 05:51 AM
Retired.
, At Large
If you're looking for most fuel efficient speed, 52 is about the best, but be prepared for a lot of one fingered salutes... There's a reason the highway mileage for cars and trucks is tested at 50.
Probably the best speed/mileage speed would be 60-62. With our Burb and trailer combo, we get 8.2 at 60-65 mph At 75 we get 6, so it drops off pretty fast.
Of course, we get 9 without the trailer...
06-02-2010, 06:21 AM
1958 26' Overlander
Mesa
We tow between 60-65mph. I had a blowout once on my Excursion towing at 70mph and will never do that again.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
06-02-2010, 06:29 AM
1977 27' Overlander
Trotwood
, Ohio
I agree with Terry. About 60/62 and let the rest of them go burn up all that fuel. Just keep right to avoid some of the one fingered salutes and the rest are just showin you thier IQ.
Relax and enjoy the ride.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
2006 19' International CCD
Olathe
, Kansas
60-65 for me in the rh lane. Better mileage and it keeps me from having to slow down/speed up as much or having to pass a semi. Also with a single axel it's safer for me and everyone around me. it's amazing how much better mileage you get @ 60 mph. Have a fun and safe trip.
06-02-2010, 07:11 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We do about 65 mph on the interstate. Downhill we hit about 70, and on an uphill, we're usually down to about to about 60.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
06-02-2010, 07:15 AM
1972 Argosy 20
Middletown
, New Jersey
I keep it at between 60 and 65 , though sometimes my heavy size 13s does make it creep up a tad...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
06-02-2010, 07:16 AM
1993 25' Excella
Full Time
, Anywhere USA
We set the cruise control at 62. Towing at this speed in the flat states we get 17 mpg and in the mountain states 13.5 mpg. (2008 GMC 2500HD)
Michelle & Leon
New England Unit
06-02-2010, 07:18 AM
2008 22' Safari
Oracle
60-65 and we avg 16 mpg if don't have a headwind.
06-02-2010, 08:14 AM
1989 25' Excella
1989 34.5' Airstream 345
Hobe Sound
62
After we started to travel in our MH (1st one a 26' 77 GMC and now our 89 345) have settled pretty much on 62. Seems not to increase much time, and the fuel savings is substantial. Example, from home here in SE Florida to New Mexico I figured mabe an extra 4 hours travel! Even towing a 66 Tradewind with then our 2500 Suburban, followed much the same speeds. If we have a 2-3 hour run and are late, 70 is no problem, but sucks the fuel.
06-02-2010, 09:13 AM
1972 23' Safari
NSB
Thanks for all the replies. We're looking at a 3 hour drive with normal driving and I think about 2 hours of it is interstate. I'm tempted to be more conservative driving there and more aggressive on the return to see what the difference it. And we'll be on I-4 through Orlando on a Friday afternoon so I'm sure we'll get many one-finger salutes. Makes me want air horns.
06-02-2010, 10:18 AM
1970 27' Overlander
Espanola
, Full Timer
.......................and dye your hair white, get a old straw hat and corn cobb pipe with a checkered shirt and keep looking straight ahead...also move your mouth like your missing your false teeth ha ha!
06-02-2010, 10:33 AM
You have a pretty good consensus going here. We have found over the years that we settle into a sweet spot between 58 and 62. We tend to drive some long distances. With our rear, we're running at 2850 -3000 at those speeds. I must confess the ride really smooths out over 70, but over the speeds mentioned here we drop about 2 mpg. That's a lot when your getting 9-10 mpg at best.
Another consideration, in addition; how large is your fuel tank? You may find your range severely limited. If you need to use your roof air and the onan, you can probably count on not much improvement in mileage or possibly less over engine air alone. The limitation is that your generator feeds of the vehicles tank and can only access from the top half of the tank or so so you don't get stranded at the campground. Hopefully you have the 50 gal.
Hope this helps
Keith
1968 17' Caravel
Battle Ground
No matter how fast you drive, there will always be people who just have to get ahead of the RV. You can never go fast enough for them. I ignore them all. Find the speed you're comfortable with and stick with it.
Stephanie
06-02-2010, 10:53 AM
Incorrigible
1976 Argosy 24
, Georgia
We tow our Argosy between 55 and 60 mph.
We just completed a trip to Kentucky and back in our motorhome. 55mph except on longer hills when I turned off overdrive and set the cruise on 50 mph. We received 1 small air blast from a passing tractor trailer at 55mph. Otherwise, no rude comments that I noticed.
Tim
1976 24' Argosy
1973 International Harvester Travelette 1210 4x4 'Bernard' 164" WB
1997 Georgie Boy 30' SuperDuty v10
06-02-2010, 11:05 AM
2005 22' Safari
Gresham
, Oregon
I usually try to keep it under 65 miles per hour. I don't thinkt ST Tires are built for anymore speed than that. jc
2005 22 ft Safari LS
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
06-02-2010, 11:06 AM
2006 16' International CCD
Niagara Falls
, New York
We do 60-62 max. Mileage drops off fast when you go fast. It's safer with the trailer too.
06-02-2010, 11:22 AM
1972 23' Safari
NSB
We have a 50 gallon tank. The generator needs some work from sitting so roof air while running is out for now, and of course the dash air isn't working. A wonderful combination for Florida summers.
06-02-2010, 11:51 AM
1965 22' Safari
Vassar
, Michigan
Speed
We run around 62 on the freeway. TV is an 09 Silverado 4x4 w/5.3 gasser. We get 14 mpg all day long until a head wind. Not bad but remember our 65 vintage 22' Safari is not very heavy.....Tim
Tim
TAC MI 14
Everyday is a Saturday
