Old 10-28-2012, 06:49 PM   #1
Sioux Falls , South Dakota
What should we look at?
After two years of research, we've narrowed our focus to diesel pushers. We want an air bag suspension, side radiator, and diesel-powered generator. Yesterday we looked at a 96 Land Yacht which lacked all three major items. What models should we look at? Brand of engine is not critical. There are other areas that might be of concern, but for now, which Airstream DP models will have those three features?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 10-28-2012, 08:04 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
David,
Look through the 'Flat-Front' threads. Really can't say that ALL of your desires are to be met, but that's a good place to start. From '94 to '96, Airstream did produce a Classic diesel pusher, but not sure if it has side radiator, diesel generator, but certain that the air susupension is there.
As well, check the 'For Sale' section here on the Forum, you may just find your new Airstream!
Good Luck, Derek
Old 10-28-2012, 08:07 PM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
You are just about out of luck.
Airstream did not make a side radiator model, ---- EXCEPT FOR THE LEGACY ON THE SPARTAN CHASSIS. But the Legacy is built on the lighter Chassis and has much lighter specs than the later Airstream Flat Front models.
I would not get hung up on that issue. You get a large side compartment on the Airstream motorhomes that you will not get on the side rad models.
See my thread on Class A Motorhomes Available.
http://www.airforums.com/forums/f313...ml#post1209248
See also, the thread "Rebirth of the Airstream Class A"
http://www.airforums.com/forums/f313...ml#post1197559
and be sure to put down your wants and desires so that it will be included in the new model Airstream Class A coming soon?
Dave
Old 10-29-2012, 06:35 PM   #4
Dave, thanks for the links, especially the second one. I've added my thoughts to it. It doesn't look like an Airstream is in our near future, but who knows.
TAC SD-6
AIR 54240
