Old 11-04-2006, 08:40 AM   #1
1991 35' Airstream 350
Windsor , North Carolina
Weep hole covers
When replacing weep hole covers--what do you do with the hollow (rivet?) on the bottom? Pull it out, drill it out, replace it (with what?)
ralley is offline   Reply With Quote
Old 11-04-2006, 01:40 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Do you have any photos?
Fyrzowt is offline   Reply With Quote
Old 11-04-2006, 03:43 PM   #3
1982 28' Airstream 280
Norfolk , Virginia
Ralley
I drilled out the rivet that held the weep hole cover in. When re-installing, I used a stainless screw so I would not break the little loop. I also use some 3M Super Weather Strip Adhesive as a mastic. A little dab will do ya.
Steve
Geophilist is offline   Reply With Quote
Old 11-04-2006, 03:53 PM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I riveted mine on using a standard pop rivet.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-04-2006, 04:19 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Are we talking window frames here? (considering several other drainage hole locations; eg, C-channel -- but this is a moho subforum so I'm in over my head )
5 meter Langford Nahanni
Old 11-04-2006, 04:24 PM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I used stainless steel rivets. It is doubtful any water will ever leak into the rivet hole and if it does the amount would be so small that whatever damage done would not be noticeable until I am poking up daisies.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-04-2006, 07:34 PM   #7
noiva's Avatar
Chesapeake , Virginia
Images: 46
Either method will work. Slightly less risk probably with screws, but not enough to worry about.
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 11-05-2006, 09:56 AM   #8
Thank you all,
Best,
R
Old 11-08-2006, 09:46 AM   #9
silver buffalo's Avatar
Floyds Knobs , Indiana
Where did you'all get your new covers? Did anyone ever find a source besides the $6 and $8 dollar one from Airstream? I need to replace about 75% of mine (missing or broken) and I know the new ones will look so good I will have to go on and replace them all but at three per window.... the bill gets hihg real quick.
Rick Hill
83' 310
AIR # 2905
silver buffalo is offline   Reply With Quote
Old 11-08-2006, 09:52 AM   #10
noiva's Avatar
Images: 46
Try Vintage RV at this link directly to the weep hole covers - both sizes. http://www.vintagetrailersupply.com/...12&Search.y=10 I've dealt with these folks, and been very satisfied. Watch the shipping charges at some other places.
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 11-08-2006, 10:04 AM   #11
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
there is a member here who makes these from a polymer, they look great and hold up well, I used them on my moho. Hopefully he will chime in at some point, or you might be able to search related threads.
AIR #005
retired!
Window Covers kzener40 Airstream Motorhome Forums 9 03-25-2012 05:27 AM
Roof Vent Covers Dwight Roof Vents, Skylights & Fans 2 10-13-2003 10:16 AM
Tire covers Andy Fay Tires 1 11-16-2002 06:03 AM
outside window covers 83Excella Rock Guards, Segment & Window Protectors 2 06-30-2002 06:24 PM
sink covers Larry Brown General Motorhome Topics 1 06-28-2002 09:35 PM
