Old 12-05-2010, 07:48 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Water Valve On/Off Positions
I have a 2003 Gas Land Yacht. I need advice from someone with a similar rig.
I'm trying to get this straight in my head. When pushing pink stuff thru the system I place a pump and tube in a gallon of anti-freeze connected to the street water intake to get pink stuff in all the lines. To bypass the water heater I believe I should close the top and side valve and open the bottom valve. Is that correct? What position should the valve handle be when it is "closed"? That is straight across the water line? My manual does not show which position the handle must be at when closed. Sorry to be ignorant but I can't seem to get this right. I think I'm pumping antifreeze in my hot water tank. Also, I assume all three valves under the bed should be closed, once again, what position is closed? Thank you.
Steve
spat61 is offline   Reply With Quote
Old 12-05-2010, 08:33 PM   #2
shelocta's Avatar
1990 25' Excella
Pflugerville , Texas
Steve;
The is what I have in my '83 MO. If I remember correctly it never tightens like a normal valve. This my help.
Bill
Give me 40 acres and I'll turn this rig around.
shelocta is offline   Reply With Quote
Old 12-06-2010, 10:17 AM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Spat,
It helps me to visualize what I am trying to accomplish. Perhaps that will help you as well.
To start with, we need to stop the water from going into the hot water tank. But we need to be sure the hot water line itself gets the pink stuff all the way back to the faucets. If you close all three valves, then you will stop the pink stuff from going into the hot water tank, but you will also prevent the pink stuff from going any further. So, you need to close the valve going into the hw tank, and close the valve in the line exiting the tank. But you want to keep the pink stuff flowing, so you must open the one that bypasses the tank and allows pink to flow.
The setup I have is in kind of an H shape. close the left and right (or top and bottom) and open the one that is in the cross-bar of the H.
If that looks nothing like what you have, then perhaps someone with a rig like yours can help.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 12-07-2010, 08:23 AM   #4
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
First of all I never use the :Pink Stuff" anymore. That stuff tastes like ****! We tried every year to flush it out of the lines to eliminate the smell and taste but never could. I now use Vodka. That's right Vodka! The cheapest stuff I can find. It takes about four fifths and it has advantages.
1. No taste.
2. Sanitizes.
3. Anti-Freeze.
4. Spring party.
I also have a bypass for the water heater. Just a piece of flex line that fits into the ends of the in and out line on the water heater. I then drain the water heater separately.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 12-07-2010, 08:35 AM   #5
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
Your unit should look similar but the bypass Pex tubing should be white on one side of the 90 degree ball valve and red on the other.
Close the top, open the middle and shut the bottom. Disregard the text on the right of the photo.
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 12-07-2010, 08:56 AM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Patrick, As always, a picture is worth a thousand words, but shouldn't the note on your picture say "open" this valve when winterizing rather than "close?"
Seems to me that the bypass valve would be closed in the normal operating position.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-07-2010, 11:30 AM   #7
1968 17' Caravel
Images: 79
Brian & Connie,
I googled the image and posted it, disregard the text on the right of the photo.
Old 12-09-2010, 05:29 AM   #8
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
I like the Vodka idea!
Robfike is offline   Reply With Quote
Old 12-09-2010, 09:43 AM   #9
Ready-to-Travel
pmclemore's Avatar
RE the vodka: I was wondering if vodka could cause damage to water lines and seals the way ethanol-added gasoline is said to be hard on boat fuel systems.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 12-10-2010, 08:07 AM   #10
The Hawk's Lair
cooperhawk's Avatar
Pat
Heard a lot of nay sayers say that when I first started, but so far, after more than ten years I have had no problems what so ever.
I do wonder what the Highway Patrol would say about a motorhome traveling down the highway with vodka available right out of the faucet?
AKA THE GUNNER
VFW, LEGION, NRA
Old 12-10-2010, 08:15 AM   #11
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I like the vodka idea, but I would prefer bourbon. Sal.
noreen&sal is offline   Reply With Quote
Old 12-10-2010, 09:27 AM   #12
Ready-to-Travel
pmclemore's Avatar
10 years is a pretty good test. And since I winterized my rig using less than 2 gallons of the pink stuff, at $4.50/gallon, cheap vodka would not be that much more expensive.
I think I'd add a little pink dye to the vodka so I could monitor its progress through the system. Although if I bought better vodka, I could monitor it by tasting, couldn't I?
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 12-10-2010, 09:32 AM   #13
noreen&sal's Avatar
1981 27' Excella II
Use a couple of drops of red food coloring. Sal.
Old 12-11-2010, 08:30 AM   #14
The Hawk's Lair
cooperhawk's Avatar
Pat
We can tell by the smell or just a little taste on your finger.
AKA THE GUNNER
VFW, LEGION, NRA
city water valve nynick52 Fresh Water Systems 5 08-04-2009 11:42 AM
shower water valve, water is cold!!! cnsilver Sinks, Showers & Toilets 3 11-02-2008 06:51 AM
Gray water valve ? Pacerized Waste Systems, Tanks & Totes 10 05-29-2007 05:17 PM
Water drain valve? ldetsf LP Gas, Piping, Tanks & Regulators 2 11-29-2006 04:57 PM
Water valve help mtnman Fresh Water Systems 18 04-12-2006 05:31 PM
