Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 07-14-2003, 11:58 AM   #1
rdm
rdm's Avatar
Profile:
Unhappy Water Heater Replacement (help)
Our atwood water heater has a leak on the side next to the outer wall. When this unit is replaced is it a simple job or a difficult one. This heater has the rad hoses hooked up to it where is the best place to buy a replacement.
This seems to be our year for appliance problems
RAy
rdm is offline   Reply With Quote
Old 07-14-2003, 03:31 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Replacing the water heater is not hard. You need to be sure to get the right model that has engine heat as an option.
The new one should fit into the old hole without any cutting or modification in the skin. SAve the old door as it should fit and you would have to order the door from Airstream if you want an aluminum one. The one that comes on the heater will be white.
I have bought 2 heaters for diffrent MH from http://www.rvcatalog.com They seem to have the best prices and freight is free. Here is the link to the atwood page
http://www.rvcatalog.com/default.asp...6KD7GNCB2TCR0A
You may want to call them as the only one with the heat exchanger is also a 120 volt model. It does have DSI ignition too for gas. You could install it and not use the 120 volt option and still save money on the unit from them.
Good luck.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 07:47 AM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 11:29 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
Hot Water Heater Replacement rpwx Water Heaters, Filters & Pumps 0 08-25-2002 08:44 AM
Water Heater Replacement, Others roessler Water Heaters, Filters & Pumps 9 06-18-2002 04:53 PM
