Old 02-09-2006, 07:15 AM   #1
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Water heater replacement
I am getting ready to replace the water heater in the 345 due to a tank leak. The water lines are all the grey plastic with crimp type fittings and metal bands. Are the crimpers available? The bands? Is this something I can get at Lowes? Or does everyone just replace them with hose clamps?
Thanks, Rob
Robfike is offline   Reply With Quote
Old 02-09-2006, 08:05 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Lowes and HD should have everything you need. It is called PEX tubing. Crimpers are around $100, but you may be able to rent the tool. They have compression fittings that fit the tubing also. I used the compression fittings on my replacement project. Also ran the PEX to the toilet. Most of the plumbing in my coach is still copper.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-09-2006, 09:48 AM   #3
Robfike's Avatar
Speedway , Indiana
Thanks, I will check them out.
Old 02-09-2006, 09:59 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used some compression fittings and changed to copper and brass as I had a leak in my shower. Sealed it very tight, and has never been a problem. I guess the pex holds up, but its an option anyway.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-09-2006, 11:23 AM   #5
Sadly, no it isn't. PEX is either white, red, or blue. The grey tubing is polybutylene. The crimps and connectors are no longer available as no code allows them anymore. The tubing itself works fairly well, and is still available. Do a search on "polybutylene" on this site for more than you want to know.
The easiest fix is to use Flair-it brand fittings. They will work on both PEX and polybutylene. Many RV stores and some hardware centers carry it.
Mark
'85 Sovereign, 25'
Old 02-09-2006, 05:02 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Rob,
Flair-it is a good choice. No tools needed. Be careful to hand tighten only or you'll distort the gasket inserts. Also, if you do have polybutylene, be sure to use the tubing inserts in the ends of the tubes before putting on the fittings.
Old 02-10-2006, 05:25 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
The grey is the poly stuff that has been didintegrating in peoples homes? I did not know that...glad I went to a metal fitting and pipe in the shower!
AIR #005
retired!
Old 02-15-2006, 12:23 PM   #8
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I would switch over to copper. It is easier to obtain and easier to work with. Plus I feel that a good soldered joint will not rattle loose. One more benefit is that in the chance happening you get some freezing copper will survive a little better than most of the plastics out there.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 02-15-2006, 01:26 PM   #9
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Originally Posted by Chaplain Kent
...One more benefit is that in the chance happening you get some freezing copper will survive a little better than most of the plastics out there.
Ouch! I have had many people say just the opposite--platic will survive a freeze and copper splits. I can verify that copper does split, but don't know if it's sooner or later than plastic would do in the same circumstance. On the other hand, I have taken apart a couple of copper plumbing systems the froze and at first I thought I could replace a few split pipes, only to discover that the fittings (those that had frozen) had expanded permanently.
Roger
Old 02-15-2006, 02:30 PM   #10
Roger
It depends upon the plastic. PCV or CPVC is prone to breaking if frozen. PEX has a some ridiculously large expansion quotient before breaking. What is seldom mentioned is that the regular PEX connectors are all brass, which could split. Even so, if freeze protection is you main concern, PEX is the material of choice.
Mark
'85 Sovereign, 25'
Old 03-01-2006, 06:50 PM   #11
Robfike's Avatar
Speedway , Indiana
Water heater up date
I just finished installing the new water heater. The biggest problem was getting the new unit through the hole in the side of the coach.
THE PLUMBING: As I was able to get a lot of great help from everyone on the forum, I was able to at least ask the right questions to find parts. I elected to go with the PEX white tubing and only crimp type fittings with one exception. The fittings are copper as well as the crimp rings. I was able to find the crimp fittings that are for Poly on one end and PEX on the other. These I used to go from the old stuff to the new. I used the new by-pass kit from Camping world. The only fittings that are not 100% crimped are the ones that connect the PEX to the by-pass fittings. These are a swivel type screw-on fitting.
You should be able to see in the photos how it all is put together.
This really is not a big deal. I did pop for the crimping tool at $97.00. I think it will be handy when I need to replace something else.
I had to go to Lowes, and Menard's to get all the tubing and fittings that I needed.
In the last photo, you can see the "go..no-go" guage that comes with the crimper. You should check each crimp. The other item in the photo is a tubing cutter. I got this at Lowes and it works great.
I can't wait until Spring!
Name:	AS Water heater 002.jpg
ID:	18868   Click image for larger version
Name:	AS Water heater 003.jpg
Name:	AS Water heater 004.jpg
ID:	18870   Click image for larger version
Name:	AS Water heater 006.jpg
Name:	AS Water heater 007.jpg
ID:	18872   Click image for larger version
Name:	AS Water heater 010.jpg
Name:	AS Water heater 011.jpg
ID:	18874   Click image for larger version
Name:	AS Water heater 012.jpg
Name:	AS Water heater 013.jpg
Old 03-01-2006, 08:31 PM   #12
lewster's Avatar
The reason that the RV industry went away from copper was a simple one: It tended to work-harden and break from the constant motion going down the road. I see this from time-to-time in older motor homes that were wired with solid copper electrical wire also. Makes you nuts when you have no power where it should be and you finally trace an open wire in a perfectly good looking piece of Romex.
I'll stick to plastic water tubing and marine grade stranded wire, thanks! Besides, the plastic like Qest annd Flair-It are way easier to work with than copper and a torch .
Old 03-02-2006, 09:00 PM   #13
RivetAddict
swebster's Avatar
Louisville , Kentucky
Nice job!
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 03-02-2006, 10:10 PM   #14
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
RobFike,
Excellent post on the water heater replacement.
One question ---- What type of fitting did you use to screw into the water heater? Brass, Poly, Qwest pex, etc. ?
I need to stop and get a bypass kit on the way home from Sarasota. It is nice to see they use a backflow valve. My old one did not.
wingfoot321 is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water Heater Replacement rpwx Water Heaters, Filters & Pumps 2 04-23-2014 01:43 PM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater Replacement, Others roessler Water Heaters, Filters & Pumps 9 06-18-2002 03:53 PM
