Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 06-12-2019, 06:18 PM   #1
1988 34.5' Airstream 345
Lafayette , Louisiana
Vinyl flooring
I am renovations our 345 classic and going with a vinyl wood floor and they come in glue down or floating. What is the best way? Glue down or floating floor?
Jim Keaty is offline   Reply With Quote
Old 06-12-2019, 08:54 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
we used floating, click-together flooring and would use the same stuff again. No movement or noise on the road, and it can be taken apart and put back together as needed.
Waipio Rim is offline   Reply With Quote
Old 06-12-2019, 09:32 PM   #3
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Do not use the peel and stick. I did and even with meticulous prep, it has shrunk in both dimensions. Replacing with floating laminate. Heavier, but it will be the last floor I have to install. Best wishes
NavyCorpsman is offline   Reply With Quote
Old 06-13-2019, 06:01 AM   #4
flooring
Thank you for the intel! Also what type of underlayment or vapor barrier should I use? I would like it to be as insulated as possible. Also, do you think I can sue the same flooring over the engine and under the passenger and driver seat?
Old 06-13-2019, 09:55 AM   #5
Waipio Rim's Avatar
Honokaa , Hawaii
Our laminate is heavy too, at least 1/2” thick. We laid it directly on the subfloor, but a vapor barrier is probably a good idea. I think that I saw that Bob Miller put a heating system under the floor in his 370, an even better idea if you go where it’s chilly. Not sure that I am enough of a carpenter to make it work in the cockpit and doghouse, left carpet there.
Old 06-13-2019, 01:31 PM   #6
I might be wrong but I think Dan (Smartstream) might have installed wood flooring in the cockpit area.
If so maybe he could post pictures of his installation.
1975 24' Argosy Motor Home
Old 06-13-2019, 11:16 PM   #7
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Damn Brad you have a good memory, you wouldn't believe how long it took me to find these old pictures.
Anyway I used Brazilian Teak because according to the specs it is very hard and stable size wise with changes of humidity, also got a great deal. It isn't too bad to cut but it eats saw blades. Measure and cut accurately because there is no give, it either fits or it doesn't. I glued it and screwed it down. I will say I replaced a click together cork floor which I liked but it didn't last very well with our Great Dane. The Teak has held up very well however two planks seemed to have shifted a bit and I have no idea why or how.
This is how it looks.
The work around the throttle and steering column was a bit...tedious.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-14-2019, 05:18 AM   #8
When something impresses me I tend to remember it
Interesting description! I'll bet it was more than tedious
Best way to remove Vinyl from interior vinyl clad Eric H General Interior Topics 11 10-21-2013 11:32 AM
Roll Vinyl vs. Vinyl Tile in Bathroom? Roadrunner Repairing/Replacing Floor &/or Frame 6 09-29-2011 07:23 AM
new vinyl over vinyl cabinets? Aage Cabinets, Counter Tops & Furnishings 28 09-29-2009 07:50 AM
vinyl tile vs. one piece vinyl loki Repairing/Replacing Floor &/or Frame 69 02-18-2007 03:38 PM
Vinyl Wood Flooring bill benton Repairing/Replacing Floor &/or Frame 6 02-03-2007 10:52 PM
