Old 07-07-2014, 04:21 PM   #1
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Valterra valve solution
Owned MH's for many years and finally decide to fix rather than replace the Valterra valve on the holding tank. Valterra puts out a good valve however it gets stiff after a few years or non use. The one I have now has been in the MH for about 3 yrs, limited usage and shouldn't be hard to open or close, drilled 1/8 inch hole, tapped in a thread and a few squirts of oil it is smooth again. You can use self tapping screws or bolts. Valve was used two months ago, tank was flushed until it ran clear, just to make sure I ran the hose again today and when I drilled out came brown water, valve holds water, one more reason to modify, would be a shame to destroy a valve by freezing the water held in it.
Once oiled all three valves worked smooth, now I have spares Middle picture shows how to move handle to make drilling easier, this valve is only a backup valve in case of primary valve having a problem on the road.
Bottom picture shows where to drill and tap a screw, if you want freeze protection you might want to do two so that water will flow out the low point, my concern was getting oil in and only drilled the high side.
ID:	215891   Click image for larger version
Old 07-07-2014, 05:24 PM   #2
2005 19' Safari
GLENDALE , AZ
I have been carrying a spare valve around for a couple of years, waiting for the T-handle to come off in my hand. But now, I'm going to drill a hole and oil mine, too!
I wonder if a 1/4" (miniature) grease zerk-fitting would fit? They even make one that has tapered, concentric ridges/rings that can be tapped in with a hammer, instead of screwing it in.
Great idea! Thanks for the tip and photos!
Old 07-08-2014, 06:37 AM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Like the idea of a fitting but not the hammer, valve is plastic and wacking it might disturb the rubber o-rings or crack the case. Oil flows to the two tracks on either side of the valve and the shaft but you would have to put in a lot of grease to fill the entire interior and then when you pull handle you would have to displace grease and whatever worked its way past the o-rings around the sliding sealing plate.
Old 07-08-2014, 07:18 AM   #4
Kevin245's Avatar
Thanks for sharing this idea Dave. I carry a spare valve gate assembly in my parts kit for the same reason. I had to change both valves out in our Avion last October. The front two connecting bolts were readliy accessible but the back two were on the blind side and were difficult to reach. The bad part was that the old zinc plated bolts had corroded so much that there was no way to unbolt them even after dropping the belly skin.
I ended up slicing through the gate body with a sawzall without damaging the flanges. I used stainless hardware on the new valve gates.
What type of oil are you using for lubrication?
Eleanor Roosevelt
Old 07-08-2014, 07:25 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
on other RV forums I have read of people installing a grease fitting and filling it with grease. Haven't tried it my self.
My valve is the low point in the tank and a few ounces of cooking oil does wonders. Also loosening the bolts that hold the valve together a 1/4 turn can help a lot as the valves age
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-08-2014, 08:23 AM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Do you just pour the cooking oil into the tank through the toilet? If that works it sounds like that would be the most simple solution...
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 07-08-2014, 09:31 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Larry C
I do, but my valve is horizontal and the low point so if the tank is empty all the oil goes there. On a vertical valve it would be more difficult. The theory is the cooking oil won't have an adverse affect on the seals where a petroleum product might cause swelling
13 Ram 2500 TD
Old 07-24-2014, 08:51 PM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I used what I had in a plastic squeeze bottle labeled machine oil with a tube for getting in small places, feels like 10 wt, but unknown. The cooking oil recommendation makes sense for next time, time to fill a small bottle and put it in the sewer supplies.
Glass on a Valterra dump valve? 63air Waste Systems, Tanks & Totes 4 04-02-2011 09:29 AM
Looking for Valterra dual dump valve Zstream Waste Systems, Tanks & Totes 4 11-16-2009 11:27 PM
Valterra dual dump valve part number? Zstream Waste Systems, Tanks & Totes 0 11-08-2009 04:42 PM
Valterra Valve question 65CV Waste Systems, Tanks & Totes 0 07-14-2009 10:14 PM
Replace a Thetford Valve with a Valterra? thunder433 Waste Systems, Tanks & Totes 2 03-03-2008 05:41 PM
