Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 03-12-2004, 10:02 PM   #1
zduke4x
zduke4x's Avatar
Profile:
vacuum system ques?
Just found a portion of the vacuum system I was unaware I had!
Looking for a water system drip in commode area and found the vacuum parts under the sink boxed area....cannot find any on/off switch but do have some unaccounted wires under front room table....does anyone know where the switch might be located?
Thank you, jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Old 03-12-2004, 11:22 PM   #2
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Do you mean "central vacuum"? If so many of these turn on when you insert the vacuum hose into the wall socket.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 03-14-2004, 08:32 AM   #3
zduke4x
zduke4x's Avatar
Profile:
no hose
Thanks for the info.....I have no hose though....is there anything special besides the correct diameter about the hose?...jem
The Silver Buffalo
WBCCI # 14067
Old 03-14-2004, 08:57 AM   #4
swebster
RivetAddict
swebster's Avatar
not sure. See if you can get a model number from the vac, then start an online search or stop by your local vacuum repair store.
Steven Webster
AIR 1760
ThisOldRV.com
Old 03-14-2004, 12:29 PM   #5
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
JEM,
The vac system is normally just the motor and blower. The bag was in the hose and handle. If you stick a normal vac hose in it the switch will contact and it will run, but without filtration. I had one in our 76 Argosy. The bags for the OEM "dust bubble" are no longer made. You might be better off retrofitting a really small shop vac into the space and using it if you want the central vac features.
Of course all of this only applies if it is like the one I had If it has a bag in the built in portion you can just get a hose and a few attachments
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 03-14-2004, 12:38 PM   #6
zduke4x
zduke4x's Avatar
Profile:
thanks for the info!
I guess I will convert the vac box to storage for more stuff! I have parquet flooring so a broom and a swifter does fine...jem
The Silver Buffalo
WBCCI # 14067
